Reload this Page >
removing decals
removing decals
Old 01-29-2015, 09:23 AM
halflight
Default removing decals
discovered that I put the decals in the wrong place on my warbird
is there an easy way to remove the decals without messing up the covering
Old 01-29-2015, 10:10 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Assuming you're talking about iron on covering like Monokote ot Ultracote and stick on decals??,, some warmth from a heat gun can loosen up the adhesive making them easier to peal off,, likely you'll need new decals either way.
good luck
Old 02-05-2015, 10:13 AM
Luft-Gangster
ditto above. pull slowly and place on wax paper for reuse.
