fale safe settings
The best fail safe setting is usually throttle low or cut, with trim for a glide, with a gentle turn.
There are different settings possible, depending on what radio, model, etc. etc.
To me, an overlooked area has to do with long term vs short term settings.
I.E.with a momentary loss, hold last settings might be appropriate. A longer term loss
would call for the above described settings. And then, there is default trim at turn on.
