Reload this Page >
OS FL 70 Piston Removal
Old 04-28-2015, 07:20 PM
Ottdave
Default OS FL 70 Piston Removal
I recently obtained an old FL 70 four stroke in a purchase of several planes. I would like to replace the bearings but am having trouble removing the piston and rod so I can take out the crank. I have removed the cylinder sleeve but can't determine how to remove the piston/rod from the bore. How do I do this?
Old 05-03-2015, 01:06 PM
Gray Beard
My Feedback: (-1)
I know how I do it but if you go into the glow engine forum and OS support Bax can probably give you a much better answer.
Old 05-05-2015, 05:53 PM
mscic-RCU
mscic-RCU's Avatar
should be two holes in the cylinder. Line up the wrist pin with the holes and knock the wrist pin through the holes.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
