Gas engines
Old 05-12-2015, 08:01 AM
gphil
Default Gas engines
Got a Evolution .15cc gas pumped engine. The muffler has a fitting for tank pressurization. Is this needed to the tank? Thought pumped , it was not necessary. New to the gas environment so some questions have surfaced. Not doing any fancy flying so what prop is recommended for cruising with a gas eng. ? One more , what type of vent system is good. Ok thanks again and will be watching. . . gphil
Old 05-12-2015, 08:39 AM
600Bob
I don't have one. I believe when it was first introduced they used muffler pressure like a glow engine. The new pumped carb wouldn't need it and there is no mention in the manual of using muffler pressure.
Old 05-12-2015, 10:24 AM
gphil
My thoughts but the muffler still has the fitting. Block it off I guess.....gphil
Old 05-12-2015, 01:16 PM
BarracudaHockey
BarracudaHockey's Avatar
You don't use muffler pressure on a gasser with a pulse pump carb. Block it off, a piece of fuel line with a screw in it is the easiest way
Old 05-12-2015, 01:31 PM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
The early evolution small gassers did not have pump carbs and required the muffler pressure. Check to see if you have an early version, which I suspect, because of the muffler tap.
Old 05-12-2015, 01:52 PM
BarracudaHockey
Ahh yes, I forgot about those...
WEFRTD
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
