Reload this Page >
Brushless motor issues
Old 05-13-2015, 09:43 AM
Tundrahog
Tundrahog's Avatar
Question Brushless motor issues
Have a Seawind, just got it out of storage. All channels work correctly. Throttle is not working correctly.
I arm the motor(full throttle, beeps. Close throttle, beeps). I try to increase throttle and the motor is jerking, little spin. Increase to half and the jerking just stops.
I just built a MIG15 and it has the same issues. Same Tx. This would point me to the transmitter, but everything looks good.?.
Old 05-13-2015, 09:59 AM
mikey1964
My Feedback: (-1)
Sounds like the radio. Had the same thing happen to a radio that sat a long time. 72 mz Old futaba more then 10 years old.
Old 05-14-2015, 02:17 PM
Tundrahog
Tundrahog's Avatar
It was a connection issue from ESC to motor. On both planes.?. Glad it was not the Tx.
From WhiteCrest in Electric Aircraft forum:
If a brushless motor oscillates, one of the motor connections is bad and resoldering the connectors will often correct the problem.
Old 05-17-2015, 02:58 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
on the seawind it's typical symptoms of it getting wet,, on the jet??
Old 05-17-2015, 06:57 PM
jester_s1
Moderator
You can check your throttle channel by plugging a servo into it. If the servo moves correctly, your transmitter is fine. Your symptoms could be a bad motor, bad ESC, or (less likely) a bad connection. I've had those symptoms with both a failing motor and a failing ESC, so I can say that both are suspect from personal experience.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
