futaba 6 ex radio
hi
i have a 6ex my thottle servo is jumping around when i bring it back to idle this is the only servo doing this so not once but 2 x i change the servo still doing it so i change the recvier with a new one i have and it is still doing it, i pin it down to the radio pod can i use contact cleaner spray to clean the pod once i take it out of the radio ,thanks
Moderator
The pot, you mean? If the pot is dirty, some isopropyl alcohol on a Q tip will clean it right up. But the pot may be worn, in which case it will have to be replaced.
If you're using a servo extension did you isolate that as well? Try swapping channel at the receiver and see if the problem follows.
If it were me I'd send the transmitter in for service or get a bigger computer transmitter
I believe he is asking about the stick "pot" (the potentiometer). If it's jumpy, then it's likely worn or dirty. In almost all cases, it should be replaced. Usually, though, if one of the pots is bad, then all of them are likely near the end of their useful life, and should be replaced, too.
For transmitters compatible with the R617FS receiver, you'll need to get one of the FASST transmitters: 7C, 10C, 14SG, or 18MZ.
https://www.aliexpress.com/store/pro...708186381.html
Replacement potentiometers for Futaba 6EX !!!!!
