Reload this Page >
Old Magnum Pro 40 FSR-ABC
Old 06-09-2015, 02:41 PM
doc8254
Default Old Magnum Pro 40 FSR-ABC
I ordered new bearings for this engine that someone left in my clubs Field Box and was wondering if I should use some Loctite bearing set on each? Also, is there supposed to be an O ring between the carb and the bearing housing? There wasn't a Glo plug in it and need to know what that might be? Thanks for any help!
Old 06-10-2015, 05:25 AM
jester_s1
Moderator
No need for bearing set. Glow engines are made for the bearings to be a tight fit in the crankcase. When you install the bearings, heat the crankcase to about 250 degrees in your oven before pressing in the bearing. That will expand it enough to let the bearing slide in and seat properly. You install the main bearing on the crank first, then slide the crank into the crankcase. Then you install the front bearing onto the crank and install the front end parts and tighten the prop nut quickly to seat and align everything.
Yes, all carburetors need an oring to prevent air leaks.
An OS #8 glow plug should work.
Old 06-10-2015, 02:18 PM
doc8254
Thanks! Now for the bearings to show up from Boca!
Now I'm wondering if this engine has a head gasket? Nothing there when I took it apart. If there is one req'd, where do I find one or use for a substitute?
Last edited by doc8254; 06-10-2015 at 03:39 PM. Reason: More questions after looking at the response
Old 06-10-2015, 10:44 PM
jester_s1
Moderator
Download the manual online. It will show a head gasket in the exploded parts diagram if there should be one. There usually isn't though.
Old 06-11-2015, 03:09 AM
doc8254
The manual for that engine I cannot find. I looked at an exploded view of a .46 but it was a different type of engine.
Thanks again for your response! The older I get the more I worry about everything! lol
Old 06-11-2015, 07:52 PM
jester_s1
Moderator
Well, normally there is no head gasket on an ABC engine. So you're probably fine without one.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
