Midwest Aero Star 40 Kit
If you can't find a manual, see the RCU Magazine section up top. There was a January 2003 build review of this plane that should get you most of the way through the build. Unfortunately Page 2 is missing which probably had the CG and throws information. However, you probably won't go wrong with balancing on the main spar and using the throws from just about any other .40 sized trainer that you can find a manual for as a starting point.
My Feedback: (18)
Thanks, but that is an article on the ARF, I am looking for the instruction build manual for the kit. Giving the kit to a new be, I could build it from the plans myself but the book will help him on his first build.
