Reload this Page >
What is speed 400
What is speed 400
Old 08-12-2015, 09:44 AM
imblaze88
Default What is speed 400
Hi I have a plane that calls for speed 400 and after some research I assume it's an old brushed motor? What size brushless would I need to replace it? What kv rating? Plane is a cap 232 33" wanting all around 3d
Old 08-12-2015, 04:43 PM
imblaze88
Anyone? Seems no one ever replies anymore
Old 08-12-2015, 06:25 PM
52larry52
You might get a better response trying in the "Electric Aircraft Universe" section just below the "RC Airplanes" section you are in. Someone there will be able to answer your question.
Old 08-13-2015, 03:18 AM
imblaze88
I cant find the sub forums either, it only gives me a handful to choose from
Old 08-13-2015, 04:18 AM
RCPAUL
It's a brushed motor where the 400 is (I think) the length of the can in millimeters.
Old 08-13-2015, 04:41 AM
ForcesR
This will suit your needs, or you could pick another brand motor which would be similar in power.
Roger
[h=1]Power 10 Brushless Outrunner Motor, 1100Kv[/h][h=2]Key Features[/h]
  • Equivalent to a 10-size glow engine for 32–48 ounce (910–1360 g) airplanes
  • Ideal for 3D airplanes weighing 28–36 ounces (790–1020 g)
  • Ideal for models requiring up to 450 watts of power
  • High-torque, direct-drive alternative to inrunner brushless motors
  • Includes mount, prop adapters and mounting hardware
  • External rotor design—5mm shaft can easily be reversed for alternative motor installations
  • Slotted 14-pole outrunner design
  • High-quality construction with ball bearings and hardened steel shaft
  • Quiet, lightweight operation
[h=2]Overview[/h]The Power 10 is designed to deliver clean and quiet power for 10-size sport and scale airplanes weighing 32 to 48 ounces (910 to 1360 grams), 3D airplanes weighing 28 to 36 ounces (790 to 1020 grams), or models requiring up to 450 watts of power. It’s an especially good match for the E-flite Brio 10 for high speed F3A precision or artistic aerobatics.
[h=2]Product Specifications[/h][TABLE]
[TR]
[TD]Type:[/TD]
[TD]Brushless outrunner motor[/TD]
[/TR]
[TR]
[TD]Size:[/TD]
[TD]10-size[/TD]
[/TR]
[TR]
[TD]Bearings or Bushings:[/TD]
[TD]One 5 x 14 x 5mm Bearing, and One 5 x 11 x 5mm Bearing[/TD]
[/TR]
[TR]
[TD]Wire Gauge:[/TD]
[TD]16[/TD]
[/TR]
[TR]
[TD]Recommended Prop Range:[/TD]
[TD]10x5–12x6[/TD]
[/TR]
[TR]
[TD]Voltage:[/TD]
[TD]7.2–12[/TD]
[/TR]
[TR]
[TD]RPM/Volt (Kv):[/TD]
[TD]1100[/TD]
[/TR]
[TR]
[TD]Resistance (Ri):[/TD]
[TD].043 ohms[/TD]
[/TR]
[TR]
[TD]Idle Current (Io):[/TD]
[TD]2.10A @10V[/TD]
[/TR]
[TR]
[TD]Continuous Current:[/TD]
[TD]32A[/TD]
[/TR]
[TR]
[TD]Maximum Burst Current:[/TD]
[TD]42A (15 sec)[/TD]
[/TR]
[TR]
[TD]Cells:[/TD]
[TD]6–10 Ni-MH/Ni-Cd or 2–3S Li-Po[/TD]
[/TR]
[TR]
[TD]Speed Control:[/TD]
[TD]35–40A brushless[/TD]
[/TR]
[TR]
[TD]Weight:[/TD]
[TD]122 g (4.3 oz)[/TD]
[/TR]
[TR]
[TD]Overall Diameter:[/TD]
[TD]35mm (1.40 in)[/TD]
[/TR]
[TR]
[TD]Shaft Diameter:[/TD]
[TD]5mm (.20 in)[/TD]
[/TR]
[TR]
[TD]Overall Length:[/TD]
[TD]43mm (1.60 in)[/TD]
[/TR]
[/TABLE]
Old 08-13-2015, 01:57 PM
Gray Beard
My Feedback: (-1)
http://www.wattflyer.com/forums/ If you were able to locate the Q&A then just a couple more down, the very bottom, is the electric forum. The reason no one gave you a reply was they didn't know. Larry gave you a perfect reply.
Old 08-13-2015, 02:00 PM
imblaze88
Thanks everyone I got it figured out at wattflyer, thanx again for the replies
Old 08-13-2015, 09:34 PM
airraptor
My Feedback: (66)
That power ten is about four times the power of a speed for can motor lol The Eflight park 380 inrunner is the closest motor or any inrunner of 20mm in Dia and of 35mm in length if want to run close to same size props. A park 300 with a bigger prop is more efficient as it spins a bigger prop. The Speed 400s were around 100 watt motors
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
