Reload this Page >
servo mounting on wing
Old 08-14-2015, 01:16 PM
rye
My Feedback: (10)
Default servo mounting on wing
hi
i have a taper wing on a chipmunk what is the proper way to mount the wing servo mounting in the wing so it work the aileron with out binding
thanks
Old 08-14-2015, 02:52 PM
daveopam
My Feedback: (9)
daveopam's Avatar
One servo in the center or one in each wing panel?
Old 08-14-2015, 06:48 PM
rye
My Feedback: (10)
thanks but do i angle the servo so that its in line with the aileron or keep it straight in the wing
Old 08-15-2015, 01:23 AM
RBACONS
It does not matter. It is only important that the linkage, at neutral, is perpendicular to the control surface leading edge. This can be done by having the servo arm perpendicular to the servo case and angling the servo case or by having the servo case parallel to the wing ribs and angling the servo arm. 6 of one, half-dozen of another.
Old 08-15-2015, 02:24 AM
RCPAUL
Rbacons +1
Old 08-15-2015, 03:42 AM
Jennifer Curtis
If you mount the servo parallel to the
wing ribs, the pushrod should go straight
back from the servo arm 1/4 to 1/2 inch,
then bend out so the end of it points
directly at the aileron.
Jenny
Old 08-15-2015, 06:19 AM
All Day Dan
All Day Dan's Avatar
Here's what I do. Dan.
Old 08-15-2015, 07:09 AM
daveopam
My Feedback: (9)
daveopam's Avatar
Sorry I did not totally understand your question. You got great advice above. I like to make sure the arm and servo case are parallel to the hinge line.
david
Old 08-15-2015, 08:08 AM
flycatch
My Feedback: (26)
http://www.rcuniverse.com/forum/gian...-geometry.html
Old 08-15-2015, 08:20 AM
j.duncker
j.duncker's Avatar
Jenny
The above is not best practice. Avoid bends in pushrods if you can. Short straight pushrods are best.
Also it will make no difference to the aileron movement in relation to servo movement.
Post 9 has a link which is worth reading through.
It does not matter what angle the servo is mounted. What does matter is the angle of the servo ARM in relation to the hinge line of the aileron. If you want equal amounts of UP and DOWN aileron then the servo arm should be at 90 degrees at rest.The control horn holes should be above the hinge line.
For a model like a Chipmunk it is not too critical but slightly more up aileron than down is good. Don't sweat it and go fly it.
HOWEVER with some models you want large unequal amounts of up and down. EG my Stampe biplane I had about double the UP compared to down. It is possible to do this mechanically or if your TX allows it on the servo set up. With equal amounts you would have severe adverse yaw which could result in the model turning right when a left turn was commanded by aileron.
Old 08-15-2015, 06:31 PM
drac1
drac1's Avatar
Jenny
Do not do this.
Old 08-16-2015, 03:29 AM
Jennifer Curtis
Originally Posted by j.duncker View Post
The above is not best practice. .
Did you miss the 1/4 to 1/2 inch part? If this bend is
this close to the servo horn, no bending will happen.
Even in a crash, any bending will happen midway
along the pushrod. I know this from experience, and
no the crash was not caused by the bending, it was
caused by not extending the 72 MHz antenna.
Jenny
Old 08-16-2015, 04:18 AM
RBACONS
Any bend introduces a point which facilitates flexing of the pushrod. Is it a big deal? Not on small planes or slow-flying planes and I've used it on occasion but nonetheless it is still not an ideal geometry.
Old 08-16-2015, 12:41 PM
jester_s1
Moderator
I had a bend in my aileron pushrods once similar to this with no ill effects. The pushrod only needs to be as strong as the servo torque. If you can command full deflection while holding the surface still and the pushrod doesn't bend significantly, the linkage is fine.
Old 08-16-2015, 02:47 PM
j.duncker
j.duncker's Avatar
This is not as simple as that.
FLUTTER is the issue. OK with something slow it will not happen often but get the speed up and one day you risk hearing the dreaded BRRRRRRP followed by the model coming apart in mid air.
Keep those pushrods short and straight.
Old 08-16-2015, 04:19 PM
Jennifer Curtis
Flutter is what will happen if the servo horns get
the holes worn from not putting the slight bend
in the pushrod, and just let the z-bend force its
way at the incorrect angle.
Jenny
Old 08-16-2015, 04:37 PM
drac1
drac1's Avatar
+1
Old 08-18-2015, 09:06 AM
flycatch
My Feedback: (26)
Simple fix for a push rod that is bending is to sleeve it with copper tubing.
Old 08-18-2015, 01:06 PM
RBACONS
Even better is carbon fiber tubing. Light and stiff.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
