Reload this Page >
rcexl kill switch
rcexl kill switch
Old 08-15-2015, 09:47 AM
katman74
My Feedback: (23)
Default rcexl kill switch
Is there anyway to hook up a rcexl kill switch to a R617 receiver if all channel are occupied.
Old 08-16-2015, 03:10 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
It needs it's own channel to function, you can Y it with the RX power input if that's taking up a slot
Old 08-16-2015, 07:33 AM
jetmech05
The blacks are all tied together and the reds are all tied together inside the receiver. In other words they're bussed together. So a Y harness would work
Old 08-16-2015, 09:14 AM
scale only 4 me
My Feedback: (158)
Yes, but you can't Y it to a channel that has another function, it uses the signal wire to operate also, to activate/kill the ignition.
Old 08-17-2015, 06:26 AM
jetmech05
You sure about the kill switch using the signal wire? Or is it that the kill switch just uses the power.
Old 08-17-2015, 10:26 AM
scale only 4 me
My Feedback: (158)
I believe the OP is asking about how to connect to the RX,m not how to power the module
Most power the ignition module with a separate battery pack as intended, I'm pretty the wire to the RX only powers the switch function and it will not power up the module.
Even if it did and you could power it that way the kill function still needs it's own TX to RX channel function so the only thing you can feasibly "Y" it to would be the RX power input.
I think you're confusing a IBEC with an Optikill switch, the IBEC would get power from the RX pack.
Old 08-18-2015, 03:51 PM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
that kill switch needs a signal wire to operate. It is just like a servo. If you are using channel 7 as the reveiver battery channel, you can wye the kill switch and the battery together into port 7, and activate what ever switch you want to operate the kill switch.
Old 09-03-2015, 08:06 PM
Bcolici
Bcolici's Avatar
Just an fyi, it can also be modded to use it as a ibec.
Done fairly easy too if you have some soldering skills.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
