Prop size
Old 09-06-2015, 11:22 AM
cran
Default Prop size
I have a Hanger 9, P-47, with a Satio FA 100 in it. It seems to come in too fast for landings at an idle. The prop size that I have on it now is a 14x8. Should I go to a 15x6 or 14x6 prop to help slow the plane down for landings?
Old 09-06-2015, 02:22 PM
bhady
I'd try the 15X6, the larger prop disc will create some drag at low RPM and help you slow the plane down. It may also help vertical performance.
Old 09-06-2015, 03:14 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
The #1 cause for a fast landing airplane is being too nose heavy.
Old 09-06-2015, 04:42 PM
cran
Thanks for the help, I will try the larger prop and recheck my balance, Thanks again.
Old 09-07-2015, 04:11 AM
Greg Wright
Greg Wright's Avatar
Does the it have flaps?
Old 09-07-2015, 01:20 PM
JPMacG
14x6 is not enough prop in my opinion. I would try a 15x6. I have a 14x10 on my Aeromaster with a Saito 100. I need the pitch to keep the RPM down to meet my fields sound limit. With the 14x10 I have to fly it onto the ground. It will keep on flying with the engine at idle.
Old 09-07-2015, 03:45 PM
cran
Hi Greg, This is the Hanger 9 ARF P-47 that was out 5 or 6 years ago. No flaps just ailerons.
Old 09-08-2015, 11:52 AM
jaka
Hi!
As the others have said_14x6 is too small. 15x6 or perhaps 16x4.
And check the Cof G! Nose heavy planes tend to land fast.
Old 09-08-2015, 01:35 PM
j.duncker
j.duncker's Avatar
Something I have done when faced with a similar situation is to reduce the idle on thew final leg. I would often just use the throttle trim as i was comfortable doing this and would count the beeps.
But with a modern computer radio it is usually possible to attach the lower idle to a switch.
Old 09-08-2015, 03:13 PM
Gray Beard
My Feedback: (-1)
As speed said, it is usually more of a CG thing then the prop. Still, the only way to tell what prop you like is by testing. And when testing don't forget the three blade props. The 14 is not too small of a prop but it may be too small for that combo. I don't often use a three blade but they are like putting on the breaks when you cut power. I also have the three way switch set up like JD mentioned. Up is a high idle I use to start and while in the air, center is very low for while in the pits or taxi/landing and down is kill. Works for me.
Old 09-08-2015, 04:24 PM
cran
Thanks to all that have replied to my question. I have changed the prop to a 15x6 and will check the CG as time allows. This week end looks like a rain out so I will have to wait until next week end to test fly, Thanks again to all replies.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
