Reload this Page >
diaphram on a G 26
diaphram on a G 26
Old 09-07-2015, 12:15 PM
tazzzz
Question diaphram on a G 26
Im replacing the fuel diaphragm on my G26. which way does the gasket fit, Does it go on top of the diaphragm or underneath it against the carb?
THX TAZZZZ
Old 09-08-2015, 05:43 AM
Gizmo-RCU
My Feedback: (27)
If its a Walbro as I remember its on top toward the cover plate. There is lots of iformation on the internet on Walbros......
Old 09-08-2015, 05:47 AM
Greg Wright
Greg Wright's Avatar
http://outdoorpowerinfo.com/repairs/...wt631_carb.asp
Old 09-08-2015, 04:08 PM
tazzzz
It's a walbro wt645. That's what I thought but to make sure I'm doing a search. ..and getting different answers. I need to get it right before I install it. Thanks for the comeback. TAZZZZ
Old 09-08-2015, 05:16 PM
Gizmo-RCU
My Feedback: (27)
Any small engine repair place should give you your answer, they are about all the same.
Old 09-09-2015, 03:36 AM
jester_s1
Moderator
Understanding how it works helps. The pump flaps seal on the carb body. If you put the gasket between the diaphragm and the body, there will be a space there and the flaps won't seal. It's really simple once you know, but I made that mistake once.
Old 09-11-2015, 11:11 AM
tazzzz
so what you are saying is the gasket goes up against the carb body right? With the diaphram against the cover. TAZZZZ
Old 09-11-2015, 04:14 PM
Gizmo-RCU
My Feedback: (27)
Other way around
Old 09-11-2015, 04:20 PM
tazzzz
I found the schematic. It shows the diaphragm goes on top of the gasket against the cover.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
