Reload this Page >
Painting and hinging a depron wing?
Old 12-14-2015, 07:12 PM
maxwell 1
maxwell 1's Avatar
Default Painting and hinging a depron wing?
Hi all Iam building with depron for the first time planing on using Blenderm tape for my hinges, do I paint first or hinge first? thanks Max
Old 12-14-2015, 09:12 PM
bikerbc
I would think you should paint first . I am just guessing though . I havent done that so far .
Old 12-15-2015, 02:13 AM
TomCrump
TomCrump's Avatar
Just guessing, but I'd put the tape on the depron, and then paint. If you paint first, your hinge would be bound to the paint, and not the depron. You would then be depending on the paint's bond to the surface, instead of a bond to the surface itself.
By the way, Maxwell, I lived in Marion until 1985, when I moved here for a job.
Old 12-15-2015, 07:55 PM
blvdbuzzard
The foamies I have painted, were after I had the tape hing all done. The tape took the paint better than the foam, so it was a touch shinier than the bare foam. Other than that, it works well.
Buzz.
Old 12-15-2015, 10:18 PM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
To get the tape to adhere to the depron, you need to seal the depron. Most of the time we just rub a coat of glue onto the depron where the tape goes, let the glue dry, then apply the tape. The paint would probably do the same thing.
Old 12-16-2015, 06:08 AM
j.duncker
j.duncker's Avatar
Paint first then hinge.
How are you going to paint ? It is easy to add lots of weight. I used a cheap airbrush and just misted on some waterbased acrylic.
Tiny amount of epoxy to give a good grip for the tape helps.
Keep it light they fly better that way.
Old 12-16-2015, 06:04 PM
maxwell 1
maxwell 1's Avatar
Thanks for the help everybody, Max
