Reload this Page >
Anylink 2 Tactic Hobbico
Old 12-21-2015, 07:03 AM
velivole
Default Anylink 2 Tactic Hobbico
Hello,
I have a problem with the module
http://www.tacticrc.com/anylink/anylink2.html
It passed in custom mode setup and rest blocked in this configuration.
Impossible thus to return in mode programming for my Spektrum
Have you a solution to bring out of the custom mode setup or to make a reset ?
Many thanks
Best regards Guy
Old 12-21-2015, 11:21 AM
Bax
Page 2 of the manual states how to set the mode manually. There is a small hole that has a switch under it that will allow you to change which transmitter LED setup is selected.
Old 12-22-2015, 01:24 AM
velivole
Thanks for the answer !
I bought a second module which I settled without any problem and which works perfectly.
I think that the first module is defective
Regards
Guy
