Reload this Page >
need help from you guys i have a futaba super 8 fg
Old 01-02-2016, 11:28 AM
rcworld2000
Default need help from you guys i have a futaba super 8 fg
ok i need help from you guys i have a futaba super 8 fg i have it programmed for 23 planes . but i have 2 planes that when the left stick is just 2 dashes past half the nitro engines are at full throttle ?
Old 01-02-2016, 03:21 PM
RBACONS
Assuming you have the throw on the servo set up correctly, it sounds like you have a throttle curve programmed in, or the throttle mixed in with some switch.
Old 01-02-2016, 06:55 PM
rcworld2000
It's a fresh program on radio. Throw is correct.
Old 01-03-2016, 05:43 AM
RBACONS
Have you tried going to the servo monitor screen to verify that when you move the stick past half throttle, the servos commanded to full? If it does, then there is an unintentional mix somewhere. If it does't, then the servo itself is likely set up wrong.
Old 01-03-2016, 10:59 AM
rcworld2000
i tried that . and no the command isnt full when the throttle is wide open?
the servo command is right in line with the stick. but the throttle is wide open
Old 01-03-2016, 05:55 PM
rcworld2000
I've been thinking and the servo horn on that servo is way longer than I use (I got the plane on trade) I use the standard 4 point horn then I cut off three points. He use a long dubrovnik almost like you use on your elevators or rudder etc.
