de-bonder for c/a
I'd use a debonder and let it sit for a bit and then take a razor blade to it.
Jaka, not everyone has access to straight nitro or nitromethane. To use easily obtainable fuel, you soak the structure with oil, destroying it anyway. Debonder is readily available, it works and is easy to store.
Well guys a fellow club member told me to get finger nail polish remover from the dollar store, as that is what he is using so I figured for a buck why not. guess what it works great what I found is you have to keep it wet about 20 min, and it comes loose with no problem. Then let the parts dry for about an hour and you are good to go..
Cheers Bob T
AMA13377
Cheers Bob T
AMA13377
I tried plain acetone and nothing ? will try again and keep it wet longer. The nail polish remover I got has 1% acetone and dimethyl carbonate, dimethyl succinate, dimethyl adlpate/caycerin, and benzoate and water all in various amounts so don't know what worked.
But now it is over and I am moving ahead again
Cheers Bob T
