low voltage for lipos
4.4 on the NiCad is fully depeleted.
I run LiIon on my big airplanes, I recharge at 7.1 volts at a 1 amp load. Now I am regulated to 6.5 at the servos and 5 to the receiver so I have a cushion. I'm recharging now at 7.4 volts but I'm gonna fly tomorrow all day.
Moderator
Lipo is pretty much completely discharged at 3v per cell. So for a an 11.1v pack that would be 9 volts under a light load, a bit more if you are measuring open voltage. NiCds can go to 1v per cell under load. FWIW, measuring open voltage doesn't really tell you much, because the voltage the meter sees is so affected by the pack's internal resistance and the small load the meter sees. Two packs that are similarly discharged may show several 10ths of a volt difference in their readings because of those factors. There is the voltage the cell is producing, and then there is the voltage that the meter actually sees. Measuring voltage under load, using the same load each time, practically eliminates those variables and gives you a true indication of how much charge the battery has left.
