Mixing 20% oil FAI fuel
My Feedback: (14)
IN
Ok, guys, this is one of those things that I can't get my mind around. I want FAI fuel, 20 % oil. Just confirm or correct. For 1 Gallon or 128 oz. I use 25.6 oz oil and fill the remainder 128 oz with methanol. That would be 25.6/128 = 20%. I'm having a mental block here for some reason.. thanks..
Here's another simple method. Get a 1/5 whisky bottle. Place a mark on the neck close to the full level. (I use masking tape.) Fill the bottle up to the line with oil once, and pore it into your gallon container. Then fill it four times with alcohol. This will give you a 4 to 1 mix, or 80% 20%. No measuring required!
Hi!
???? Aren't you having methanol and castor oil in separate containers...that you mix in a 1 liter jar??
Fill the jar with 2 deciliter (20%) castor oil and 8 deciliter (80%) methanol...that's 1 liter FAI fuel.
My Feedback: (14)
IN
Any one have a good synthetic oil they would recommend?? I used Klotz Techniplate in the past, but's pretty expensive now..
