Drilling holes in the leading edge of a wing
NC
I have a 1/8 scale Spitfire ARF and I want to make holes in the leading edge of the wing to add machine gun ports is there any special tips on how to do this or just drill away?
Also, once you get through the covering, the flutes of the drill bit will have a tendency to tear into the wood and rip it out instead of smoothly cutting it out. (That's because most of the drill bits available to us are actually designed for the high speed cutting of steel.) Using an electric drill or Dremel will be difficult to control. If you drill it by hand, you'll have better control AND can instantly stop in case the bit suddenly tries to grab a chunk of wood.
Good Luck!
Harvey
Good Luck!
Harvey
When I do something like that I cut a small slot ( X) in the covering then use a drill in a handle and do it by hand . Another way to keep from ripping the wood is to take a " tube " the size you need and cut small slots in one end and use it as a drill . That's only good for softer woods but works for me . ENJOY !!! RED
