Reload this Page >
A Pound of lead!!
A Pound of lead!!
Old 10-12-2016, 06:18 PM
flyboy2610
flyboy2610's Avatar
The instruction manual for the Top Flite Elder 40 says that the prototype required 12 oz. of lead in the nose to balance. You gotta do what you gotta do.
Old 10-13-2016, 03:48 PM
chucksaw812
That's what I'm going to have to do..the three servos in back weigh a total of 5 ounces..once I move those forward it will help a lot!
Old 10-13-2016, 03:49 PM
chucksaw812
Gonna move the servos from the tail to the front..that should help a lot.. I hope...
Old 10-13-2016, 03:50 PM
chucksaw812
How does it do with the 1.20?
Old 10-13-2016, 03:51 PM
chucksaw812
The instructions give a measurement in inches for the balance point..not sure how to figure the 33%..
Old 10-13-2016, 03:53 PM
  #31
chucksaw812
That's a good idea!..I like the epoxy idea!...thanks!
Old 10-13-2016, 04:00 PM
  #32
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Very easy on a constant cord wing. Measure the cord and multiply by .33
Old 10-19-2016, 12:26 PM
  #33
buzzard bait
Good plan to move the servos and use carbon rods. Might not quite get you there; if not, you can make a battery box in front of the firewall with a hole for the connector to the rx. Then if you still need just a little more, hopefully a heavy hub will get you there. I hate adding much weight too. The design has a short tail and a small stab, so the CG probably doesn't have much leeway.
Jim
