Are fuel tank mounting curious ?
why is it the arf planes tank mounting always below the fuel intake . Every time I put one together,mounting the engine upright, the tank is always below the recommended position. Engine manufacturers state to make sure the fuel line be in line with the carb. seems to me manufacturers should be aware of this. I mount all my glows upright. I've always wondered about this.
Well not every arf is intended to have upright mounting, many are intended for ninety degree and others for fully inverted.
Factors such as the depth of the forward fuselage for example most ARF J-3 cubs intended for glow power use a ninety degree mount not just to make it look scale with the cylinder sticking out the side but also because of the relatively shallow depth of the forward fuse. It is difficult to get the fuel tank high enough without grinding out that pretty instrument panel and this is made worse when oversized fuel tanks are used.
Every airframe has a different circumstance for the intended engine mounting. Now having said that while most ARFs from mainstream suppliers are fine There have been some where no thought seems to been given any thought to this basic need, if a typical glow engine is to be used.
John
John
I agree.
Many (most ?) ARFs are designed for inverted, or side mounted, engine installations. I haven't seen an upright mounted glow engine in some time.
My glow powered air frames have inverted installations. I experience no problems, and the model presnts a cleaner appearance.
Pica of a pair of Kadet Seniors are posted below.
I have 2 sig kadets, 2 hanger 9 alphas and a world models super frontier, all depict upright engine mounting. They all run well (I'm not into pretty, just want to fly). I'm not particularly fond of inverted mounting,,tried it once,,,,not a fan. I run all OS engines,,,love me all. Just a curious question is all.
Waiting for hurricane Matthew to hit----- TAZZZZ
I hope the hurricane is kind to you.
For the type of models that you fly, I suggest that you mount your engines in the stance that best suits the fuel tank location.
I've had no trouble with inverted engines. I believe that fuel tank location is the key to success.
Yeah, that's what I mean. Even though the tank is not mounted in line I have absolutely no operating problems whatsoever. So, I guess I shouldn't worry so much. Anyway,gotta take down the sails
Thanks for the comeback----TAZZZZ
Indeed all your airplanes are intended for upright mounting. The Super Frontier is a clone of the Seniors and both have that lovely deep, deep forward fuselage where it easy to get the tanks up high where they need to be.
And indeed button up tight tonight we will be praying for you.
John
John
MI
either may help if you have to invert one.
I was thinking about this after posting and I wonder if setting the low end is more important, as there may be more raw fuel sumping into the glow plug and putting it out if the low end if rich.
sticks
I really couldn't tell you, I got so frustrated with getting it to run without idiosyncratic tweaking. I just want to fly without my mind worrying about the little things that might interrupt my enjoyment
TAZZZZ
TAZZZZ
MI
