Hitec 3XA and futaba 617 receiver
My Feedback: (23)
FL
Im installing a 3XA on my 50cc gee bee using a 617 7 channel receiver. With using an ignition
kill all channels are in use. My problem is trying to get both elevators to work. There both on there
own channel. Only one will work now. Am I going to have to use a servo reverser and go into one channel
No the "master" channel will be 2, then you mix 2 and 6 I believe.
As far as full channels go. In a receiver all the reds are bussed together. (Same as one) all the blacks are bussed together. The. The signal wire is white. That means for something like a kill switch you can use a Y in any channel one end of the Y to the kill switch the other to the servo
