Starter charger
Starter charger
What charger to use with Hobbico power pack starter battery?I bought a starter pack at a swapmeet to add to my starter to get rid of the cable and then the correct batteries from Hobbico but now need a charger.Any suggestions. I want to use the connecter that is in the side of the battery box.
You just need one of those octopus banana jack charge cables that have 6 or 8 different connectors on them, including a phone jack type connector. Will plug into any charger and most all chargers will handle a 12V PB battery. Or, if you you don't want to invest in a smart charger, Hobbico sells a wall charger specifically for the power pack (HCAP0901).
