Duel servo set up on dx6i
1 Post
If no one comes back with an answer for you, there is a dedicated forum for this brand of radio, try a search there or post the same question.
http://www.rcuniverse.com/forum/jr-r...um-radios-116/
I can't help you as I am a Futaba guy.
Moderator
Plug the second servo into either 5 or 6 and set up a mix for it. Alternately, you could use a Y harness on the two throttle leads, but that won't let you adjust anything.
