Nitro to gas conversation would a 10cc gasser work in place of a .46 nitro?
I have a Great Planes Corsair 40 with a super tiger .46 nitro in it. A guy is offering a trade of his RCGF 10CC rear exhaust for my OS 160 FX. Will that 10cc work well in the Corsair?
Hi Wildvortex Just an opinion here and that sure seems like a bad deal and plan. Personally the OS 160 sure seems to be a much more valuable as well as useful engine possibly down the line.
Will the 10cc work well in the corsair? I suspect it certainly will fly it But! How much fun will it be and how much more skill will it require of you, which is always the case with an underpowered airplane Remember if the airplane is decked out with retracts and flaps and all the associated servos and stuff, to that you will now have to add an ignition module and more importantly an extra motor battery pack as well as the associated extra switch.
Most of the successful conversions of warbirds normally called forty or sixty size to gas I have seen and participated in, start with 15cc engines and my favorite the OS15GT.
Only just my opinion
John
John
Yah, have about 10 gallons of nitro myself. I was asking because someone wanted to trade me a 10cc for my OS 160FX. I backed out of that deal. Would have taken it for a saito, OS or even an Evo but was a rcgc or something. Hobby King sells it for $200.
I agree about the longer prop,, a longer prop will give more "Flywheel effect" , sorry I can not give an opinion on what size, I have not flown a 40 size engine in many years,
another thing that may "may" help with the prop you use now is to try a Hotter plug, so if you use the OS8 try an OS7
Jim
Jim
Jim
Jim
Thing is I get it down close to a good idle and it cuts out entirely, no sputter or anything. So, I don't think a larger prop will help. I do get the flywheel effect though. I have been running 15% am considering trying 20% in it. The great thing is that I have access to the fuel and props without coughing up the cash.
Currently I have other things on my plate as I am in the middle of finishing the trim work on my new build room. Hope to have it done today for the most part. Then I can get organized a bit and working on these planes.
My Feedback: (54)
Wouldn't buy RCGF. Every one that I have seen or worked on, didn't run well, no power, and just a plan aggravation at the field. Stay with the OS .40-.46 until you can afford to purchase a quality brand engine. You will be happier in the long run. I have seen all of the alphabet engines come out and there are only a few quality engines that are gas. Zenoah, DA, haven't work on an OS, but probably an OS, Saito gas and glow. IF you want to fly when you get to the field, pay the $300 for the engine or stick with what you have now. IF you want to work on engines at the field, then buy your RCGF and let us know how you are doing during the first month of ownership. The old saying, "You get what you pay for" never applied more to RCGF.
you may need to change both, a Hotter plug and a longer prop, a Hotter plug will stay lit better and burn more fuel at idle, so it should produce a smoother idle, and with ether or both you may also need to adjust your idle screw and or adjust your idle RPM on your Tx,,
note that a restricting muffler can be a terrible thing on a glow engine, it can choke up your combustion and produce a week fuel tank pressure, also, for starters only go up 1 inch longer on the prop unless you have a very short prop,,
also note that a Hotter plug in many cases produces better throttle responds at lower Stick settings, and may lower your Top RPM a bit, but if your engine runs better with a Hotter plug so be it, because that is what you want and need,,, if your ever hear a "Naa Naa Naa Naa" sound from your engine the idle is too-too lean,
BTW, use a quality plug, I have no respect for a cheap brand
Jim
Jim
I run OS plugs. The engine called for a 11x6 prop. I found a 12x6 3 blade. Yes it is a big jump but was what was around. Besides the 11x6 was swollowed up by cowling. Will see how that goes.
Wildvortex I think you missed a key point here. I stated its likely you needed a "Longer -Flatter" prop. You seemed to have only read the Longer part and ignored the flatter part. If you only increased the diameter and used the same pitch without reducing the pitch you are going to induce even more severe running problem. Adding also a blade is going to be even worse than that.
The prop you stated you were using was a 11x6 a longer, flatter prop would have been a 12x5 and that was my suggestion period. Putting that 12x6 three blade on your airplane is certain to cause disaster due to severe overheating shortly after launch.
John
John
Maby I will just go back to the two blade the guy was running when I purchased it. Ugly but I guess that would be the best place to start. Stopping buy a friend who passed away and had horded RC stuff maby I can find a flatter one. Guess it was best that I didn't put it up on the test bench then. Maby he will have a 11x5. 11x6 is recommended in a two blade. Had put a 10x6 3 blade, what was available at the time. Possibly look for a 12x4 if they even make one.
John said it true,
"an APC 11x6" oow,,, I would think that would be the biggest prop you would want to put on a .40 size engine, even a 46,, cause I have an APC 11x8 on my OS 61Fx, and I use it because a 12 inch'er will pull my plane around at idle,
you may have a bit of an air leak on your engine somewhere, try tightening up your Back Plate screws and loosening the Carburetor and push down on it and re-tighten it,
BTW, what OS plug do you use ??, if it's a #10 it should be an #8 or #7,, and if it has "letters" on it, it too is the wrong plug
Jim
Jim
