Reload this Page >
gryo using two channels on eleavtors
Old 06-01-2017, 05:09 PM
Skyhawk940
Default gryo using two channels on eleavtors
Building a Kaos 90. Using two servos and two channels (ele and aux1) for the elevators. I would love to try a 3axis gyro, but I don't think it will work on the elevator, second channel. Any ideas?????? NO, splitters on ele channel!
Skyhawk940
Sandusky, OH
Old 06-02-2017, 06:22 AM
crawler tech
Skyhawk940
Sandusky, OH
You didn't mention what TX you are using but I can verify that FrSky S6R and S8R receivers have dual elevator and dual aileron capability. And for only $28 bucks I might add...
Old 06-06-2017, 06:53 AM
JohnBuckner
JohnBuckner's Avatar
The CORTEX 3-Axis Aircraft Gyro Stabilization System, from PowerBox Systems, bd-cortex - Chief Aircraft Inc.
Also avalible from DreamWorks RC jets as well as at least one other three D type supplier. Not cheap the Cortex from the german Bavarian Devil company will do exactly what you want and so much more plus the installation is super simple and the programing is far simpler than most others. The $250 unit supports five stabilized channels and the $300 unit supports 16 stabilized channels.
I am flying them in two of my turbine aircraft and they are remarkable. Some friends are also using them in large 3D stuff as well as scale types quite successfully.
John
Old 06-07-2017, 03:44 PM
Skyhawk940
I'm old school, I use a 72MZ, JR 6 chan. I also have a modern Spektrum 6 chan that I may use, need a receiver. Will the Spektrum AS3X receiver work for me? Thanks for the info. I'm new to gyros in planes.
Mike
