SIG Hog Bipe
Old 03-12-2020, 09:34 PM
Ernie P.
Default SIG Hog Bipe
I have a SIG Hog Bipe. I love the plane, but the landing gear is a bit weak or soft. The only replacement gear I have seen is a fiberglass gear set that works well but seems kind of... well, ugly. Does anyone know of a source of replacement gear that looks like the original gear but is a bit stronger? Thanks; Ernie P.
Old 03-16-2020, 02:22 PM
carlgrover
I bent some music wire to conform to the shape of the inside of the stock landing gear and bolted the wire to the gear. It stiffened it up quite a bit and made the gear usable. The main problem with that thing is the plane is considerably heavier than it needs to be.
carl
Old 03-16-2020, 07:23 PM
Ernie P.
carl
Sir; thanks for that tip. I may well wind up doing something very similar. Thanks; Ernie P.
Old 03-21-2020, 06:01 PM
Ernie P.
No other suggestions? Thanks; Ernie P.
Old 03-30-2020, 01:40 PM
badger5964
badger5964's Avatar
https://www.dubro.com/collections/la...h-landing-gear
I use this to replace aluminium gear. Used on a hog bipe too! It is heavier than original. It keeps moving from plane to plane. BTW it helps if you move the gear forward a 1/4" The hog bipe tends to nose over without it
Old 03-30-2020, 07:02 PM
Ernie P.
Thank you, Sir. And thanks for the tip on relocating the gear forward. Thanks; Ernie P.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
