Reload this Page >
Clevis soldering
Clevis soldering
Old 03-18-2020, 06:58 AM
plaurence
Default Clevis soldering
Hi all,
finishing up a scratch build. Last one was about 25 years ago😁
I'm having an issue soldering a clevis to a 4-40 pushrod.
I’ve done this many times in the 90s with no issues.
however, the solder is not wicking into the clevis. It just rolls off the rod!
im using silver solder with flux. I also tried other types of solder with no success.
could it be the type of metal that these rods are made of?
any insight would be appreciated.
Old 03-18-2020, 09:22 AM
jester_s1
Moderator
It could be a coating on the rod. Or if the rod is stainless, regular solder won't stick to it. Try scuffing it with 120 grit and tinning the rod by itself. If it won't tin, you have a metal incompatibility or bad flux.
Old 03-18-2020, 09:58 AM
plaurence
thanks
Old 03-18-2020, 03:41 PM
pkoury
The roll up into a ball sounds like the temp was to high.
Old 03-18-2020, 05:12 PM
plaurence
good point.
Old 03-18-2020, 06:15 PM
jester_s1
Moderator
It will do that if you burned off your flux with too much heat, if the wire is dirty, or if the metal is incompatible.
Old 03-19-2020, 10:43 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
I'll add,, I always take a drill bit to clean by scratch up the inside of the clevis hole before adding the flux,, I find that helps a lot
Old 03-19-2020, 10:47 AM
plaurence
good idea
thanks
Old 03-27-2020, 02:42 PM
jaka
Hi!
Use Stay-brite!
Old 03-27-2020, 02:46 PM
plaurence
Thanks Jan and all who responded.
I did use Stay Brite and it worked 🙂
Old 03-27-2020, 07:50 PM
jester_s1
Moderator
I think Stay Brite must come with a more aggressive flux than other solders. I've read several threads over the past few years saying that it worked when nothing else would. I've never had trouble getting old fashioned plumbing solder to stick with cheap rosin flux, but there has to be something different about Stay Brite.
