Fuel Tank Install
Are there any known problems when installing a tank sideways (90 degrees to the
direction the engine is pointing). This is for a fixed wing semi scale plane.
I can fit a bigger tank if it fits sideways.
I will state the obvious here. Make sure that when you build the tank you put the vent/pressure line at what is going to be the top of the tank when it is installed in the plane. Simply turning an already assembled tank 90 degrees and installing it will not work very well.
Scott
Scott
Thanks for all your comments. Actually I should have made it clearer, that I plan to rotate the tank 90 degrees in the horizontal plane. My main concern is the clunk pickup.
I'd make the clunk line a bit shorter, so the clunk is closer to the bottom center of the tank rather than one end, just to lessen the chance of picking up air when banking one way. The only other issue will be the external plumbing - making the 90 degree turn to get the fuel line to the engine. The brass tubing should be curved - don't depend on a straight exit and then curving the fuel line. Eventually the brass end will saw through the fuel line, due to vibration.
Let me throw something at you that might be a little more appealing that a single tank mounted sideways. Use two tanks mounted traditionally alongside each other. So, if you want to use a 12 oz tank, buy two 6 oz tanks. Plumb the pressure line of tank #1 to the pickup of tank #2. Run the carb line to the pickup of tank #1 and pressurize both of them from the pressure line of tank #2.
carl
carl
