Reload this Page >
Futaba Charger TX charger male connector replacement.
Old 03-11-2021, 11:44 AM
GhostriderBravo
GhostriderBravo's Avatar
Question Futaba Charger TX charger male connector replacement.
Good afternoon gentlemen. I have a Futaba TX and RX Charger. The RX charge lead is a male connector that I need to replace. It have 2 leads. One is Black which is Ground and the other lead is Black with a Red Strike. Please confirm that the Black lead with the Red Strike is the 4.8ydc lead. I just want to be sure before I do anything. Thanks in advance for your help.
Old 03-11-2021, 12:05 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
No doubt the one with red is "+", but really don't you have a volt meter? easy to check polarity with one of those
Old 03-11-2021, 12:28 PM
GREG DOE
You can check it with a volt meter. Harbor Freight has cheap ones for $7.00 or less.
If you can't afford one, check around with your friends, or school shop teacher.
The solid black lead is negative, and the red stripped lead is positive.
Old 03-11-2021, 12:37 PM
GhostriderBravo
Default Futaba Charger TX charger male connector replacement
Thanks for the reply. Unfortunately I have loaned out my voltmeter and it hasn't been returned as of yet or I would have used it. I thought I was correct. but just wanted to be sure. Thanks again for the reply.
Old 03-11-2021, 12:39 PM
GhostriderBravo
Thanks for the reply. Unfortunately I have loaned out my voltmeter and it hasn't been returned as of yet or I would have used it. I thought I was correct. but just wanted to be sure. Thanks again for the reply.​​​​​​
Old 03-12-2021, 04:54 AM
scale only 4 me
My Feedback: (158)
Yeah,, I hate loaning stuff out,,,
The chargers are the same as the servo wires,, just without the white signal wire,, The "+" is always the center wire
Old 03-12-2021, 12:56 PM
GhostriderBravo
Sorry I hit the wrong key. I have since stopped loaning out things especially to family members LOL. My thinking was correct on which wire was which.
