New servos tweeking
New servos tweeking
Put a small foam plane together, used new light cheap 9g. I plugged everything in and it seems that the ailerons lag a split second.
And the more I test it the worse it gets, sometimes servos twitch with no input on stick.
I changed out the esc a few times along with half dozen receivers that were known to work. More of the same.
I've been using Spektrum system. I even broke out my Taranis I bought a few year back sitting on a shelf,
same result but even worse. Not just servos twitching and turning but the damn throttle was activating also.
I glued the servos in like I didn't want them to come loose. I don't know what else to do but change the dreaded servos.
Appreciate any help. Thanks
Banned
WHERE are you doing this? Basement? Garage? Shed?
Point is when testing radio installs in a closed area like the above, reflections off the surrounding walls, heating/AC ducts, etc can often cause one or more servos to jitter. The transmitter too being only a couple of feet away or less can simply swamp the receiver and cause one or more servos to jitter. Especially the less expensive servos and when batteries are fresh and fully charged.
Take the whole thing outside, away from buildings and try it there. If it continues to happen then move the Tx at least 10 feet away from the Rx. If it keeps up then I'd suggest unplugging the cheap servos in the model and plug in some regular servos of a brand name and keep the ESC plugged in as well. If they behave normally then I'd say those cheap servos are to blame and should be changed. If not then unplug the ESC and see if things settle down. If they do then plug the cheap ones back in without the ESC and see what happens.
After more unplugging and plugging, I find if I take out the y harness and plug one aileron at a time it will sit there all night quiet. Plug the y harness in (which I really need to fly this plane) and all **** hits the fan. Meaning servos acting with no inputs.
Oh, since learning this I have changed the y harness out three times also, with same results.
I don't think it's ducts or something like that, I've been doing this for many years building and testing in the same room. Never had a problem like this.
Alright, originally I swapped out a couple 12amp esc with xt30 with no change. I thought why not try a couple more.
I put in another 12amp esc with xt60, no change. Then I try a 20amp esc with xt60.... and there is no twitching or false inputs.
What the hell is going on here. I don't think the connector matters but thought I'd give all info I have, if someone can figure this one out!
I wanted to try to keep it on the light side, but I've been f ing with this for weeks. I guess I'll use the heavier esc and bat and call it good.
Love to know the science behind this, if anyone has a clue let me know. Thanks
This makes no sense!!!!!
My Feedback: (29)
First off Y connectors are just bad news. Basically you are hooking up two potentiometers that will never be in sync to a single pulse. That creates a sort of feedback just like a microphone too close to the speaker. Some servos can handle the noise some can't. Not sure why you must have a Y as just about every modern radio system has dual aileron servo mixing. Having your TX too close to the RX or setting up in a confined area WAS an issue with 72mhz. 2.4 does not have those issues. I suspect that the ESC BEC is putting out different voltages. It's possible the first two were putting out too much voltage, I have seen the same thing myself when I tried to run Futaba 4.8V servos on 6.6V.
Banned
My Feedback: (29)
How about reality for one. There is just no comparison to a TX swamping the RX at close range to a weapon that shoots a focused high power wide band signal. You may want to consider sticking with the AMA forum where you can post any BS and as long as it fits the narrative they will buy it hook line and sinker. Answers like the above and answers like " Epoxy outgasses for a year " or telling somone that a 180 degree retract servo will work on a boat rudder just fine only shows a lack of knowledge. Out here in the real world your made up answers don't fly.
Banned
From the radios viewpoint going out of range and being swamped are pretty much the same thing. All that happens is the noise floor rises above the level of the transmitted signal as the receiver sees it. To the point where the receiver can no longer positively lock on to the signal. It doesn't take a weapon to accomplish this but at the same time, I don't think the government would use such a device if it didn't work.
Swamping IS a possibility in this case. Do I think it IS the cause of the issue? Not really. But why not eliminate all possible causes while troubleshooting? Or is it because you didn't think of it first?
My Feedback: (29)
First off, if I were stalking you I would have said something in that thread. Being a trained composites technician I occasionally do a search for a few key words/phrases to find areas where I may be assistance. I the intent was to stalk/troll I would have done so in that thread. I only mention it in this thread to establish your habit of misleading people.
Now back to the swamping theory. I would imagine that after setting up dozens of giant scale airplanes with up to 13 digital servos in a confined garage that I may have experienced it once. I haven't. Perhaps during the thousands of flights in sports arenas around the country I should have experienced it? Can you imagine what the noise floor is during an NBA or NHL event? Still never an issue.
Banned
Unless of course you don't agree?
Retract servos are suitable to be used only for retracts! Not boat rudders, sail control, flaps or anything else that might require a little thought.
2.4 GHz is immune to RFI.
So sayeth Speedracer the omnipotent.
To the Bit Bucket with you!
My Feedback: (29)
Unlike you I don't have to imagine. I know what the RF noise floor would be. Assuming all the equipment is properly tuned and aligned, the RF noise floor will be pretty much where it always is. Typically around negative 80 to negative 90 db. All the equipment in use should appear as individual signals rising above the noise floor.
The noise floor at those events is not going to be a fixed value, it's all dependent on the equipment used and amount of equipment. Two teams playing that are low in the rankings as opposed to a playoff game will have a very different noise floor. Fact remains that signal swamping or reflection was never an issue in over 80 different sports arenas around the country.
No a retract servo will not work on a rudder, sail. It could be used on flaps if you only wanted one setting. Why? Because a retract servo is NOT proportional, then only go max travel to max travel and have no center. Some allow adjustment of end points and nothing more.
Once again putting words into others mouths. When did I say 2.4 was immune to RF? Read carefully, I said that a 2.4 TX does not have the power output to swamp its own RX. Nor does signal reflection happen with 2.4. The last time I experienced signal reflection was in the late '70s with a Kraft AM set.
Like I said earlier, the AMA forum is more your speed. Stick to the narrative and you can make up anything you want and get the ATTA BOYS you seem to crave.
So who is making up things? I'd argue it's you, saying you said things that you demonstrably did not say.
My Feedback: (29)
Funny how when I disagree with anyone in the anti AMA forum suddenly Franklin shows up. I suppose Astro and Hydro will be around soon to troll me next.
Moderator
For the 3 children who cannot have a civilized conversation with each other about anything ever:
If you were my 7th graders, I would move you to opposite ends of the classroom and schedule a meeting with the school counselor to talk about the importance of remaining civil in polite society. As it is, you are grown men, so that's not an option. I suggest a similar solution though- don't participate in threads that the other one is already active in.
As for this thread, the question has been answered, so I'm closing it.
