Zenoah G62 prop hub
Zenoah G62 prop hub
Needing to know the diameter of the steel pinch pins, 90 degrees rotation from the notches so I know what bit to use to drill for the pins. Information from zenoah gives part number, but not dimensions.
the old drill guides for it came with a bit. If anyone knows or has the guide and bit and can find the bit size be greatly appreciated.
