Reload this Page >
Help - How to seal M3 set screw
Old 08-23-2023, 03:44 PM
txshan130
My Feedback: (114)
txshan130's Avatar
Default Help - How to seal M3 set screw
Hi All,
I have a problem.. Need help in figuring out how to seal the M3 set screw in the pics below. The set screw goes directly to the upside airline on my retract and needs to be sealed and locked in place. The threads are a bit loose making it especially difficult to seal. I have tried tried a few different thread sealants from the hardware store, but none have worked so far.
Anyone have any ideas what would keep the set screw from coming out and also seal the threads for pressures around 100 psi?
Additionally, I would like to be able to get the set screw out at a later date if need be..
Thx for any ideas...
Old 08-23-2023, 05:20 PM
GREG DOE
There is a non-hardening Permatex. I can't tell you the number. There may be other products out there that accomplish the same task. Even a good anti-seize compound might work.
Old 08-24-2023, 02:41 PM
tcrowson
If you go to the Locktite web site they have a multitude of compounds one may be what you want but they are not cheap. I have had good luck with a compound called Vibratite to keep screws from backing out but do not know if it would hold the pressure but it might be worth a try.
Old 08-25-2023, 01:08 PM
Maylon
Maybe Teflon tape ?
Old 08-25-2023, 01:12 PM
txshan130
My Feedback: (114)
txshan130's Avatar
Originally Posted by Maylon
Maybe Teflon tape ?
Unfortunately, much too small to use Teflon tape...
Old 08-25-2023, 01:14 PM
txshan130
My Feedback: (114)
txshan130's Avatar
Thx... Will take a look. I was thinking about several of the Loctite varieties... Just wasn't sure which to try and didn't want to buy them all!
Old 08-27-2023, 12:03 PM
RCoffroadracer
first I would drill and tap the hole and use a new set screw.
blue thread lock is fine for that size screw.
the best thread locker I've ever used is made by pro seal. (aka the super glue brand) I found it held up to my 1/8 scale buggy way better than loctite and permatex. I buy them at Napa
