enya 120...4-c
enya 120...4-c
Hello,
Where can i find anything on the Enya 120 four cycle?Manual to down load...Need any help you can give. Starting point on High speed needle...
Bob
Bob
RE: enya 120...4-c
Bob, Tim at Enya Support will Email you a manual. Using 15%, I think I remember starting about 1 1/2 turns out on the high speed needle, and for the low speed air-bleed adjustment, adjust the needle until the hole is half-way open. My current adjustment is about 7/8's turn out on the high speed, and almost full open on the air-bleed. (The right screw is the one directly over the hole.) Mine will turn a 15x6 at 8500. Mine is not the "R" model.
CA
RE: enya 120...4-c
MRC said they are not going to be selling Enya items but said they would email me a diagram of the R120 for free. Give them a call and see if they can help you out.
Ed
Ed
