Reload this Page >
homemade prop balancers..
Old 12-19-2003, 10:00 AM
khlash
Default homemade prop balancers..
Could someone share with me their design for a homemade prop balancer? I really would rather not buy one if its possible to make one fairly easily. Thanks.
Old 12-19-2003, 12:57 PM
Geistware
My Feedback: (16)
Default RE: homemade prop balancers..
If you can get a rod the same diameter as the propeller hole, I would use two CD's as supports for the rod thought the propeller.
Old 12-19-2003, 01:02 PM
ballgunner
ballgunner 's Avatar
Use single edged razor blades mounted in a V shap, it will take four. Fasten them to a pair of uprights a few inches apart and tall enough to clear the props you are going to balance. You will need a piece of rod the diameter of the hole in the prop hub, it should be a snug fit. When the rod is placed between the uprights and in the two V shaped blades you will have a friction free balancer. Cheap, quick and just as accurate as any other balancer.
Old 12-19-2003, 05:31 PM
Stick Jammer
I use a fingertip balancer. Does the job just fine. $4.29 at TH.
http://www2.towerhobbies.com/cgi-bin...?&I=LXK247&P=7
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
