Reload this Page >
Please Help Me Plane doesnt receive signal or
Old 12-29-2003, 05:01 PM
seismic
Default Please Help Me Plane doesnt receive signal or
I dont know what can I do for this situation
After 10m or 15m later My plane cant receive signal or Remote Control cant send
I dont know what's happening,
after this distance plane's motor stop than start than stop than start than stop....
Please Help me , how can I find problem, how can I test remote control
In manual I read "plane can control in 400M Distance"
I cant control in 10M[&o]
My Plane Model is TAIYO GEKKO
Old 12-29-2003, 07:51 PM
MHawker
My Feedback: (16)
MHawker's Avatar
Default RE: Please Help Me Plane doesnt receive signal or
Although I'm not familiar with that plane, I would suggest checking the batteries. Be sure they are fully charged. It appears it may have an onboard charger. Maybe that is not fully charging the pack. Other than that, perhaps return it to the place of purchase and see if you can exchange it for another.
Old 12-30-2003, 09:02 PM
MinnFlyer
MinnFlyer's Avatar
Does that thing have Expo?
Do like Mike said... Make sure that your batteries are fully charged.
Old 12-30-2003, 09:39 PM
Live Wire
Live Wire's Avatar
I don't know what to tell you . Here in the USA we by one one day and wonder how long it will last. The radio you have , You should check batteries, Make sure you pull the antina all the way out . Make sure you check both batteries! Whoops that radio has like Flash light batteries you will have to replace them . If this does not work you will have to take it back where you buy it! Good Luck (RC Outlaw)
Old 12-31-2003, 10:39 AM
FLYBOY
FLYBOY's Avatar
Also check that the rec antenna is not disconected and streached out as far as it can be.
Old 01-10-2004, 04:59 AM
smh582003
is the aircraft made by cclee in china? I had a similar problem with on of their a/c . A friend of mine who works in electronics had a look at it , he couldnt understand it either untill he followed the cables from the charger like positive from charger was going to positive on battery, or red to red and black to black, then when the the battery was in the aircraft the same again red to red and black to black, he saw that when it was PLUGGED INTO THE AIRCRAFT it was red to black , we didn't swap them over as I had already arranged the a/c to be sent back so I didn't want to mess it up any more. But the main thing is that yes I had the same problem as you and this is what we found. My aircraft would fly for about 30-40 paces and then it would be out of range. after checking it my friend found the wires the wrong way round at the plug end of the aircraft, it may well be its meant to be that way I don't know but it may well be worth a look.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
