Reload this Page >
soaked equipment
soaked equipment
Old 01-05-2004, 04:18 AM
David74
David74's Avatar
Default soaked equipment
about five months ago I lost my pico cub in the woods, well... on the first of january a hunter that saw it gave me some directions and I finally found it. Unfortunately in the past months it rained a lot and the pico was soaked! surprisingly the servos, receiver, ESC, motor, all submerged in water... still work!
now my question is: the receiver has the antenna cut ( about 20" are missing), how could I extend the antenna? ESC and servos have some rust on them, can I rely on this equipment?
thank you
david
Old 01-05-2004, 09:07 AM
jettstarblue
jettstarblue's Avatar
Default RE: soaked equipment
David,
Check all wires for green or black corrosion, then spray everything with WD-40, wipe off, and then blow it all off with a heat gun to make sure everything is really dry. (not too hot!) As for the antenna, check on the radio forum to get the length, then just solder on a piece to make up for what is lost.
Jetts
Old 01-05-2004, 09:38 AM
runover1
My Feedback: (10)
runover1's Avatar
Please make sure there is no live electric when you spray the WD-40, it is very flammable. Disconnect battery and everything. Good Luck.
Old 01-06-2004, 02:30 AM
Crayon
WD-40 and electronics don't mix. It doesn't conduct electricity well.
I'd suggest you clean out the reciever and the ESC with rubbing alcohol. Then clean the electrical connectors with contact cleaner from radio shack. The servo's will need to be disassembled and cleaned with alcohol and possibly lubed.
All rust should be removed with a brass brush and/or steel wool. Wash away any brush and/or rust shavings with alcohol.
If possible, the motor should be disassembled and cleaned in a ultrasonic jewlery cleaner. The commutator should be very lightly polished with 2000-3000 grit wet/dry paper. Otherwise shoot it out with motor cleaner.
Contact the reciever manufacture for a replacement antennna.
Good luck,
Erik
Old 01-06-2004, 05:52 AM
David74
David74's Avatar
thank you!
David
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
