Covering
My Feedback: (16)
RE: Covering
You can use poly U or any type of resin and even paint to lay fiberglass cloth down on sheeted surfaces, but I'll have to tell you that nothing beats epoxy for this, as it gives you time to work with the fabric and the wetting properties of lay up epoxies is excellent, why do you think it is the most widely used resin to work with fiberglass? If I were you, I would do several pieces with different materials, one other great feature of epoxy is its sandablity. Do not use polyester resin, much cheaper, but very brittle and stinks to High Heaven.
