center of gravity ????????????
TN
I have an low wing A R F made by minicaft co. no ware in the construction book dose say were to check. The plane is 36 in, long, with a wing span of 48in. I put in a 40 size motor, any help :
the CofG should be about 25-30% of your wing chord. if you have constant chord this is easy, if its tapered harder. but just in front of the highest point on the root of your wing is a good place to start.
im sure you'll get a few people throw numbers at you in a min, so hang on
NICE PAGE! i like that
but know..., if anyone is using this for flying wings and deltas the CoG is still 8% of root chord forward of the posistion given by this page or any other CofG measurments
TN
OK, GUYS NOW I AM MORE CONFUSED THAN WHEN I STARTED. THE SITE YOU SENT ME TO JUST CONFUED ME MORE. iS IT POSSIBLE THAT BY USING THE 4O MOTOR WITHOUT BALLBEARING IN THE PLANE LIKE THE CLERK TOLD ME IS CAUSING THE PROBLEM SINCE THE PLANE SPECKS SAY TO USE A 18-30 MOTOR?
as far as i know these plain bearing engines are lighter than the balled ones, so your CofG shouldnt be too far away. as long as you can balance it on your fingers just infront of the higest point, it'll be fine. i do this with the tank full to make sure the planes not twitchy when its dry.
i suspect its too nose heavy at the moment.
if you cant work out CofG i assume you cant fly solo yet, so take it to your club and someone there will be able to help. everyone has lead or screw drivers they can add to make it fly
