 RC Universe abreviations, terms and acronyms list >
Old 08-26-2004, 06:24 PM
  #101
Default RE: RC Universe abreviations, terms and acronyms list
Have a few more to add...
Lawn Dart - An airplane fuselage that lost its wings mid flight.
Stab - Horizontal Stabilizer, the flat, wide, nonmoving part on the tail.
Fin - Vertical Stabilizer, the tall, thin, nomoving part of the tail.
Hotliner - A high speed electric glider
Dynamic Soaring - Using the up and downdrafts of a slope to build speed with a glider.
One point landing - Landings usually performed by lawn darts.
Old 08-26-2004, 06:45 PM
  #102
Hi Phayd,
Thanks for the input, consider them added for the next release, probably next week.
I'm always amazed at how large this list has grown!
Fly4Fun,
Wayne
Old 08-26-2004, 06:53 PM
  #103
bldrums's Avatar
What is "bashing" ( or sometimes called "kit bashing" )
Old 08-26-2004, 07:27 PM
  #104
Hi Bldrums,
Bashing normally means that people are saying negative things about something. "Kit Bashing" would mean that people are saying negative things about kits.
Normally, when speaking, bash would mean to strike or hit.
I'll try and make up a definition and add it to the list.
Hope this helps.
Thanks for your help.
Wayne Miller
Old 08-28-2004, 05:44 PM
  #105
ORIGINAL: bldrums@adelphi
I don't know the origin of the term, but it means to heavily modify the model when you're building a kit. From the way I've heard it, it seems to be a very old term, used mostly by guys who have been building kits for a long time. There's something humorous in the term, but not knowing the origin, I don't get the joke. It may simply be the similar sound between "kit building" and "kit bashing".
Old 08-28-2004, 06:14 PM
  #106
Kit Bashing is not a derogatory term, much like hacking is not really a derogatory computer term. Like Mike said, it is to modify a kit in ways not intended by the manufacturer. For instance, putting two engines on a LT40 is a kit bash. Clipping wings is an easy kit bash. Making a Senior a biplane is another kit bash. Essentially you perform a kit bash whenever you stray from the manual.
Old 08-29-2004, 08:59 AM
  #107
Hi,
Thanks for the explaination, I've added the new definition to the list and will try and publish the new list later this week.
Fly4Fun,
Wayne
Old 08-30-2004, 11:23 AM
  #108
Just my two cents: V1 means, the maximum speed in the takeoff at which time the pilot must make the decision to , in a nut shell, take off or abort the takeoff.
V2 means, takeoff safety speed, thus when the airplane is rotated for takeoff
These terms are normally used with high performance aircraft (Jets), V1 was derived from the field length to ensure that if there is a problem during the takeoff roll, the airplane would not end up going off the end of the runway. All Jet manufacturers include a table in the flight manual with runway length minimums based on aircraft weight and air conditions ie., density altitude, temp, pressure altitude and so on. If the aircraft is limited to say a 5000 foot runway, the decision speed or V1 would be roughly half of that. During the takeoff roll when the airplane safely passes V1, with no problems, then V2 is called and the airplane is rotated and off we go..... Hope this helps
_Tom
Old 08-30-2004, 01:58 PM
  #109
Hi Tom,
Thanks for the input. I have added your information to the list and I expect to publish the new list next week.
Fly4Fun,
Wayne Miller
Old 09-07-2004, 06:24 PM
  #110
hows about ROFLMAO.....rolling on floor laughing my ***** off, seen it quite often. Chuck
Old 09-07-2004, 06:36 PM
  #111
Hi Chuck,
We have:
ROFLMAO - Rolling On Floor Laughing My β€œAft” Off (or substitute β€œaft” with your locally used word)
in the current list, hopefully this will be OK. If not let me know.
Thanks for the input. The new list will be out this week.
Fly4Fun,
Wayne Miller
Old 09-18-2004, 08:06 PM
  #112
Hi,
Here is the new list.
Fly4Fun,
Wayne Miller
Acronyms, Abbreviations, Short Forms
@ - short form for β€œat” in internet addresses, or β€œfor” in sales Example 3 @ $5.00 – 3 for $5.00
& - This is an ampersand and means β€œand per say and” can be used to replace β€œand” in a sentence
# - After a number means pounds Ex. 5# is five pounds. Before a number means number Ex. #5 means number 5. On a telephone it is referred to as the β€œpound sign”.
/ - Can be used to replace β€œwith”. Example see C/W in this list
AAC – Aluminum, Aluminum and Chrome
ABC – Aluminum, Brass and Chrome, or Aero Bird Challenger
ABL - Advanced Bimetallic Liner (bimetallic is typically brass and nickel)
ABN – Aluminum, Brass and Nickel
AC – Alternating Current, or Aerodynamic Center (of the wing)
ACT – Test to do before flying A=antenna (up), C=controls (proper directions), T=throttle (quick runup and idle)
AFAICT – As Far As I Can Tell
AFAIK – As Far As I Know
AFR – Adjustable Function Rate, used to adjust servo end points
AFS - Active Flight Stabilization system
Aft – Back of boat, plane etc.
Ailerons – Control surfaces at back of wing. Note: When standing at back of plane looking forward, and the right aileron moves up, and left goes down, plane banks to right
Analogue – In test equipment a meter with a dial (needle) read out. In RC a mechanical change caused by voltage fluctuation. Example: electrical motor control output to the motor.
ATV – Adjustable Travel Volume, limits servo travel distance either side of center, or All Terrain Vehicle
AKA – Also Known As
AM – Amplitude Modulation, an alternative transmission method to FM, not used very much
AMA – American Modeler’s Association, Academy of Model Aeronautics
AOA – Angle Of Attack
AR – Aspect Ratio, relationship between the wing span and the wing chord
ARF or ARTF – Almost Ready to Fly
ARC – Almost Ready to Cover
ASAP – As Soon As Possible
AIUI – As I Understand It
AUW – All Up Weight (total weight ready to fly. some include fuel, some don't... should include fuel though.)
AWARF - All Wood Almost Ready-to-Fly
AWOL – Absent Without Leave
b4 – Short for β€œbefore”
Bash or bashing – To change or modify a model. Also, may mean to speak negatively about a thing or person. Example, β€œkit bashing” would be speaking negatively about a kit.
BB – Ball Bearing
BBS – Bulletin Board System
BC or B/C – because
BEC – Battery Eliminator Circuit
BF – Short for Bayerische Flugzeugwerke Bavarian Aircraft Works - Willy Messerschmitt's company and makers of the Messerschmit ME109
BL – Brushless, refers to electric motors
BMEP – Break Mean Effective Pressure
BMFA – British Model Flying Association
BOB – Best On Board (passenger) or Bomb On Board
BS – Bull Stuff (or substitute β€œstuff” with your locally used word)
btt – Back To the Top, used to direct reader to the top of a forum or tell them to start over
BTW – By the Way
BUHOR – Big Ugly Hell On Rails
BUMP – Any sort of text response to get the message to the top of a forum or active again
BVM - Bob Violet Models
BYOB – Bring Your Own Bottle
C(number) - Capacity times the number. Example C10 is ten times the capacity of a battery in ma. That would be 30,000 ma (30.0 amps) for a 3000 ma (3.0 amp) battery pack.
C/(number) -Capacity divided by number. Example C/10 is the battery capacity in ma divided by 10. In the case of a 3000 ma (3.0 amp) pack this would be 300 ma
C/W – Complete With
CA – Cyanoacrylate Adhesive (a quick setting glue)
CAD – Computer Aided Design
CAM- Computer Aided Manufacturing
Carb – Short for carburetor
cc – Cubic Centimeters
CCW – Counter Clock Wise
CCPM – Cyclic Collective Pitch Mixing, a mixing of three servos to control helicopter
CF - Carbon Fiber
CG – Center of Gravity or Carl Goldberg (Models)
CGM - Carl Goldberg Models
Charge or Charging – To replenish or fill. In modeling, to put energy into batteries.
CIM – Computer Integrated Manufacturing
CL – Control Line
Cos or cus – Short form for β€œbecause”
CP – Center of Pressure, or Coroplast (it’s like a plastic cardboard they make signs out of)
CRS – Can’t Remember Stuff (or substitute β€œstuff” with your locally used word)
Crow – When flaps go down and ailerons go up, gliders usually use this as an air brake
Current – The moving of electrons through an electrical device. Designated as I one unit is A (ampere)
CW – Clock Wise
CYA – Cover Your Aft (substitute β€œAft” with your locally used)
DC – In electricity - Direct Current, or when referring to radio receivers – Dual Conversion
Dead Stick – Motor stopped and flying (gliding) without power
DGA – Damn Good Airplane (or Aircraft)
Dialed in – The model is perfectly tuned
Diameter – In regards to propellers, the distance from tip to tip of a propeller
Digital – In RC, a change related to pulse width, example servo movement, the longer the pulse the more movement. In everyday life a display that has numbers or can be read.
DIY – Do It Yourself
DR or D/R – Dual Rate, usually a switch on the transmitter to allow longer/shorter servo travel
DSC – Direct Servo Control, control of servos by a cord from transmitter without transmitting a signal
DSQ.-. disqualified or disqualification
E – Voltage (Example formula: E=IR)
EDF – Electric Ducted Fan
Elevator – Horizontal control surface at back of plane. Note: When back of elevator goes up, plane goes up.
Elevons – When aileron and elevator functions are combined. Example - delta wing aircraft
EMC - Electromagnetic Compliant
Energy – Designated as E and is the result of Power times Time usually expressed in Joules(j) or kilowatt Hours(kWh)
EPA – End Point Adjustment
ETA – Estimated Time of Arrival
E-TOC - Electric Tournament of Champions
ESC – Electric Speed Control
f - Frequency
F2F – Face To Face
FAI - FΓ©dΓ©ration AΓ©ronautique Internationale
FAQ – Frequently Asked Questions
FCC – Federal Communication Commission
FFF – Fan Fold Foam
FFL – French Foreign Legion
FG – Fiberglass
FIDO...Forget It, Drive On (or substitute β€œforget” with your locally used word
Fin – The vertical stabilizer, that is, the tall, thin, upright nonmoving part of an aircraft’s the tail assembly.
Flame – To insult or vent disapproval
Flaperons – Using ailerons as both ailerons and flaps
Flute – The veins in coroplast (the plastic cardboard) that is used in making SPAD model aircraft
FM – Frequency Modulation, most common method of transmission used today for Radio Control
FOAD - Fly Off and Die. (Substitute Fly with locally used words)
FOD - Foreign Object Damage or Foreign Object Debris
Forward – to the front of boat, plane etc.
Freq - Frequency
Frequency – The amount of repetitions in a specific amount of time. Designated as f, one unit in electricity is Hz (hertz)
FS – Fail Safe, usually a preset position for servos to move to when radio transmission is lost
FSW – Forward Swept Wing
FUBAR - Fouled Up Beyond All Recognition (Substitute Fouled with locally used words)
Fuse – Fuselage
FWIW – For What It’s Worth
FYI – For Your Information
g - grams
G - Gravity force factor. Example 1G = normal weight, 2G = two times weight
GB – Gear Box
GG – Gorilla Glue (a polyurethane glue, another common brand name is Elmer’s Pro Bond)
GMAB – Give Me A Break
GMS – Gemtec Machinery Systems (makers of GMS engines)
GP - Great Planes Mfg. Co.
GPM – Gallons Per Minute
Gr8 – Short for GREAT
GYAB – Give Yourself A Break
H9 - Hangar 9 Mfg Co
HD – High Density
Hertz – A unit of frequency defined as one cycle per second
HOC – Hot Off the Charger
HOR – Hell On Rails
Hotliner - A high speed electric assisted glider
HS – High Speed
HSN – High Speed Needle, high speed adjustment on a carburetor
HTML – Hyper Text Mark-up Language
HW – Hobby Warehouse
Hydro – short for electricity, or in SCUBA compressed air tanks (used for starting jets )short for Hydrostatic testing and must be done every 5 years
Hz – see hertz
I – Current in amps (Example formula: I=E/R)
IIRC- If I Recall Correctly
IMAC - International Miniature Aerobatics Club
IMHO – In My Humble Opinion or In My Honest Opinion
IMNSHO - In My Not So Humble Opinion
IMO – In My Opinion
In The Bones – A plane that has been build and framework completed, but is not covered yet
IPR – Intelligent Power Reduce
IRC - internet relay chat
IRCHA - International Radio Controlled Helicopter Association
ISP – Internet Service Provider
ISTM – It Seems To Me
MHO – Just My Humble Opinion or Just My Honest Opinion
J – Joule, a unit of work/energy
JIT – Just In Time, usually to receive parts just in time for manufacturing, thus reducing inventory
JMO – Just My Opinion
Joule – The work done when the force of 1 newton goes 1 meter
JR – Japan Radio
JSF – Joint Strile Fighter (F35)
KISS – Keep It Simple Stupid
Kg - Kilograms
LAR – Looks About Right
Lawn Dart – A model aircraft with its nose buried in the ground, or a model airplane fuselage that lost its wings mid flight.
Lbs. – Pounds
LCA – Landing Craft, Assault
LCD – Liquid Crystal Display
LCI – Landing Craft, Infantry
LE – Leading Edge
LED – Light Emitting Diode
LG – Landing Gear
LH – Left hand side (in reference to ships and airplanes – left hand side of pilot facing forward)
LHS – Local Hobby Shop
LiPo, or Li-Po, or Li-Poly – Lithium Polymer battery
Li-ion – Lithium Ion Battery
LMFAO – Laughing My β€œFreaking” β€œAft” Off, (substitute freaking and aft for locally used words”
LOL – Lots Of Laughs, or Laugh Out Loud, or Lots Of Luck
LOA – Length Over All, in model aircraft usually measured from tip of nose cone to end of rudder
LS – Low speed
LSN – Low Speed Needle, low speed adjustment on a carburetor
Lurker – A person who visits, and reads, bulletin boards and forums but never posts anything
LVC – Low Voltage Cutoff circuit
LWL – Length at Water Line
ma – Milliamp, one thousands of an amp
MAAC – Model Aeronautics Association of Canada
MAC - Mean Aerodynamic Chord (I think this is the center of gravity/balance point?)
mah – Milliamps per hour, milliamps times hours, milliamps a current rating used to determine the number of milliamps delivered or received in one hour
Max – Maximum
MCM – Mousse Can Muffler
MD – Stamped on side of K&B engine – means Model Direct, a direct sales promotion engine sold in late 90’s
ME – Short for Messerschmit the ME-109 was designed by Willy Messerschmitt
MG – Metal Gear
MIA – Missing In Action
Min – Minimum
mIRC - is a client program to access IRC
mm – millimeter
MK - Monokote or Mark (as in Mark II)
MT – Monster Truck
mv – millivolt
MCP- Mousse Can Pipes (mufflers made from hair styling mousse cans)
Mode 1 – Transmitter with Aileron and Throttle on right stick, Rudder and Elevator on left stick
Mode 2 - Transmitter with Aileron and Elevator on right stick, Rudder and Throttle on left stick
Mode 3 – Transmitter with Rudder and Throttle on right stick, Aileron and Elevator on left
Mode 4 – Transmitter with Rudder and Elevator on right stick, Aileron and Throttle on left stick
Mode Single stick – see single stick
MTBF – Mean Time Between Failures, a rating given by manufactures for failure rates
MTTR – Mean Time To Repair, the time for the average repair of an item
NAR - the National Association of Rocketry
Newbie – A new person or beginner
Newton – The force created by an acceleration of 1 meter per sec. per sec. by 1 kilogram
NA or N/A – Not Available
NIB – New In Box
NiCd – Nickel Cadium
NiMh – Nickle Metal Hydride
NP – Neutral Point
OAN - On another note
OHV – Over Head Valve
OMG -Oh my Gosh (or substitute β€œgosh” with your locally used word)
OMP - Ohio Model Products (or Planes?)
One point landing - Landings (crash) usually performed by lawn darts.
OTH or OTOH- On the other hand
Oz – Ounces
P – Power in watts (Example formula: P=EI)
PBF – Pizza Box Flyer
PCM - Pulse Code Modulation
PDQ – Pretty Darn Quick (or substitute β€œdarn” with your locally used word)
Period – Usually a time period and is designated as T, one unit is s (seconds)
PIA – Pain In the Arm (or substitute β€œArm” with your locally used word)
Pitch – In reference to propellers, the angle of propeller blade, the higher the number the greater the angle
Port – Left hand side (when pilot faces forward), or an opening in a boat or plane, or boat docking area
Power – Is the work done by electricity and is the result is calculated by the Voltage (V) times the Current(I). It is measured in Watts(P). (Example formula: P=EI)
Ppl or ppls – Short for β€œpeople” or people’s
PPM – Pulse Position Modulation
PQHOR – Profile Quick Hell On Rails (a SPAD aircraft)
BroBros = The Profile RC Brotherhood – the web site is: http://www.the******************.com/
Prop – Propeller
Prop Wash – The wind created by a propeller when it is turning
PSI – Per Square Inch
R – resistance in ohms (Example formula: R=E/I)
RAF – Royal Air Force
RATO- Rocket Assisted Take Off
RC or R/C – Radio Control or Remote Control
RCA – Radio Corporation of America, or Royal Canadian Army
RCM – Radio Control Modeler (a magazine)
RCU – RC Universe a web site for radio control enthusiasts
Resistance – Designated as R and one unit is  (ohm). Is a value of how much an electrical device limits the electric current: One volt applied to a resistance of one ohm has a current of one ampere.
RFI – Radio Frequency Interference
RH – Right hand side (in reference to airplanes – right hand side of pilot facing forward)
RIP – Rest In Peace
RO - radio operator
RPM – Rotations Per Minute or Revolutions Per Minute
RPM/V – Rotations Per Minute per Volt or Revolutions Per Minute per Volt
ROFL - Rolling On the Floor Laughing
ROG – Rise Off Ground, or Rolling On Ground
ROW – Rise Off Water
RTR – Ready To Run (or Roll)
RTV – It stands for Room Temperature Vulcanization and is reference to β€œRTV Silicon Adhesive Sealant”, and is similar to other silicon rubber sealant products.
Rx – Receiver
RTF – Ready To Fly
RTFM – Read the β€œFriendly” Manual, (substitute β€œfriendly” for locally used words)
Rudder – Back vertical control surface at back of plane. Note: When back of rudder goes right, plane will be directed right, works with nose wheel on tricycle gear or tail wheel on tail dragging airplane.
RV – Recreational Vehicle
SC – Single Conversion when referring to radio receivers
Sec – Seconds
SPFBD – Simplified Plastic Flight Box Design
Single Stick – Transmitter with one stick, Aileron and Elevator on X and Y axis, Rudder Knob on end of stick and Throttle (a trim lever type control on the case)
Semi-Symmetrical wing – A wing with bottom airfoil not the same as top airfoil, will be less on bottom
SPAD – Simple Plastic Airplane Design
Spec – Specification
S-PPM – A JR receiver fail safe mode that will cause the servos to β€œhold” then go to a programmed preset position after a predetermined period of time
Sq in – Square Inches
SSS - Sudden Silence Sucks
SST – Super Sonic Transport
Stab - Horizontal Stabilizer, the flat, wide, nonmoving part on an aircraft’s tail section.
Stall – In aircraft, the point where there is not enough lift to keep it flying
Starboard - Right hand side (when pilot faces forward)
STD – Standard
Stick Time – Time spent flying
STOL - Short Take Off and Landing
Strk – Stroke as in 2-strk or 4-strk
Swarf – Small particles of metal left in an item after manufacturing
Sweat – To join two pieces of metal together that have been tinned. See β€œtin”.
Symmetrical wing – A wing with same airfoil on top as bottom
T – Teeth (usually the number on a gear)
TAXI – A controlled steering and moving of aircraft under power while on the ground
TBA – To Be Announced
TBC – To Be Calculated
TBD – To Be Determined
TD – Tail Dragger
TE – Trailing Edge
TF – Top Flite
TIA – Thanks In Advance
Tin, Tinned, or Tinning – To coat with solder, usually used to β€œsweat” two pieces of metal together – see β€œsweat”.
TMTOMH - Too Much Time On My Hands
TNX - thanks or thank you
to or t/o – Take Off
TOC – Tournament of Champions
Toe-in – This is a term to describing when the front of a pair of wheels on a vehicle are pointing toward each other (inward). This is needed on tail dragger aircraft to avoid poor ground handling.
Toe-out – This is a term used to describing when the front of a pair of wheels on a vehicle are pointing away from each other (outward).
TOF – Time of flight from leaving ground to touch down. Calculation for electric TOF in minutes is: battery capacity in amps, divided by average current draw in amps, times 60
TPTB – The Powers That Be
Trammeling – Aligning fuselage, wings, horizontal stabilizer, vertical stabilizer and landing gear
Troll Post – A bulletin board posting designed to create controversy and may or may not be related to fact
TTYL – Talk To You Later
ttt – To The Top, to put an item to the top of a forum, or to start over
TVM – Thanks Very Much
Tx – Transmitter
TY – Thank You
U – European designation for Voltage, or in emails Short for β€œyou”
UC – Ultracote, or U-Control control line models - the name comes from the shape of the control handle
UNEF – United Nations Emergency Force
ur – In emails, short form for β€œyou are”
URL Uniform (or Universal) Resource Locator
UWYH - Use What You Have
V – Volt, the force required to put a current of 1 amp through a 1 ohm resistance
V1 – Means the maximum speed (point) in the takeoff at which time the pilot must make the decision to take off or abort the takeoff
V2 Is the takeoff safety speed when the airplane can be safely rotated for takeoff
VE - Volumetric efficiency
VIP – Very Important Person, In SCUBA compressed air tanks tanks (for starting Jets) it means Visual Inspection Process and must be done once a year
vs – versus
Voltage – The electrical force to drive current through an electrical conductor. Designated as V (North America), U (in Europe) and one measurement unit is V (volt)
VTOL – Vertical Take Off and Landing
VTR – Variable Trace Rate, allows different servo speeds for each half of transmitter stick
W/ - With
W/O – Without
Watt – The power used when 1 amp (direct current) flows through 1 ohm. A unit of measurement for power – see β€œP”
Wing Loading – The weight each square foot (or square inch) of wing has to support (carry). Formula for wing loading in ounces per square foot is: weight of plane (in oz.) divided by wing area (in sq. inches) times 144. For wing loading per square inch, do not multiply by the 144.
WM – World Models
WIG – Wing In Ground Effect
WTB – Where To Buy
W T F – What The Fudge or Who The Fudge (or substitute β€œfudge” with your locally used word)
WOF – Wood Over Foam
WOT – Wide Open Throttle
WW1 – World War One
WW2 – World War Two
www – World Wide Web
X-wind – Cross wind
XTAL, xTAL, or xtal – Short for β€œCrystal”, this typically is a plug in component that determines the channel (frequency) for your transmitter and/or reciever
Y-Harness – A harness that plugs into receiver and has servo two plugs, used for two servo ailerons
YCD – You Can Do
YMMV - Your mileage may vary
YHM – You Have Mail
Z-PPM – A JR receiver fail safe mode that will cause selected servos to β€œhold”, and other selected servos to go to a programmed preset position after a predetermined period of time
To cut and paste the list in your favorite word processor, first highlite the list with your mouse, then push "CTRL-C", open your word processor and push "CTRL-V".
The above is to the best of my knowledge, and should be considered a starting point. Please let me know any changes you would like to see, any suggestions are welcome.
Wayne Miller
Old 09-18-2004, 09:47 PM
  #113
DustOffUH1's Avatar
Wayne,
I'll say it again. This list is fantastic. I appreciate all the hard work you've done on it. As well as I'm sure everyone else does. U R The Man
Joe
Old 09-19-2004, 01:26 PM
  #114
Hi Joe,
Thanks, I'm glad that the list is useful.
I'm sending you a separate EM.
Fly4Fun,
Wayne Miller
Old 09-24-2004, 10:42 PM
  #115
My Feedback: (10)
When some one says scratch built. Does that mean that it did not come from a kit or does it just mean that you built it yourself?
Phillip Curtis
Old 09-24-2004, 11:11 PM
  #116
DustOffUH1's Avatar
Scratch built, to me, means you build it just from the plans,,, no kit. You can order laser cut parts if you provide the plans to someone who does that. But to me, scratch built means that, from scratch, also meaning cutting ALL the wood. Altough laser cut parts are excellent. I've never done that yet, but its in my things to do Its just like food from scratch. For example, making soup from scratch. You start out by making the stock, from scratch. You don't buy chicken or beef broth, you make it yourself (which takes some time). You cut all the veggies, meat etc yourself. I used to be a chef. Hope this helps.
Joe
Old 09-25-2004, 02:40 AM
  #117
My Feedback: (10)
I was wondering why he could not give me a mfg. name. I guess in reality he was the mfg. Would this make the plane worth less money?
Phillip Curtis
Old 09-25-2004, 10:00 AM
  #118
DustOffUH1's Avatar
If he's a good builder, no it wouldn't be worth any less money. In fact probably most scratch builts are a great deal better than ARF's. It also depends I guess what kind of hardware is used, if it includes the receiver, servo's etc. I'm still an "amature". So take what I say for what its worth
Old 09-26-2004, 01:06 AM
  #119
Default RE: RC Universe abbreviations, terms and acronyms list
Joe:
Building from someone else's plan is not scratch building.
When I started even die cutting of kit parts was rare, you had to cut all the parts from bare stock wood. Or in the case of a Joe Ott kit, the formers were paper card stock. But you still had to cut them out. Building from plans is no different from this, other than having to gather the wood and other parts separately.
Scratch building was usually done by design as you go, although some people did draw rough or even finished plans of the plane. I still mainly design as I go.
In this day when people claim to build an ARF, many have also decided to claim scratch from a published plan. It's just not so.
Bill.
Old 09-26-2004, 09:08 AM
  #120
Hi,
Thanks for the input, I've added Scratch Built, Plan Built, Kit Built etc. to the list for next publication, probably in a week or two.
Fly4Fun,
Wayne Miller
Old 09-26-2004, 11:27 AM
  #121
DustOffUH1's Avatar
Bill,
Thanks for correcting me. As I told him take it for what its worth, because I'm still kind of new at this. I guess I got the mis conception from a guy who sold me an adjustojig about a year back. I probably mis understood him. I was telling him that in the future I wanted to start scratch building. He was very nice and sent me plans for Das Ugly Stick, and a copy of the old article from MAN. He just sent it, didn't ask for any $$. I think he did that just to get me started learning how to build from plans and cutting my own wood. And I "ass u me d" that's what scratch building was. Now I know, and still a ways away from that. I guess that's why that forum is called scratch building & design
Thanks again!
Joe
Old 10-24-2004, 07:21 PM
  #122
Hi,
Here's teh latest list.
Wayne Miller
ABS – Anti-lock Braking System
AF 1 – Air Force One
ARO – After Run Oil
ATRF – Almost Ready To Fly a model that is mostly pre-assembled - see also Scratch Built, Kit Built, Plan Built, ARF, ATRF and RTF
AKA – Also Known As
BB – Ball Bearing
BC or B/C – because
BIT – Built In Testing
BTW – By the Way
C/W – Complete With
CC – Castle Creations
CF - Carbon Fiber
CL – Control Line
CR or C/R – Compression Ratio
CW – Clock Wise
DAW - Dave's Aircraft Works (bought out by http://skykingrcproducts.com/ )
DC – In electricity - Direct Current, or when referring to Radio Control radio receivers – Dual Conversion
DT – Digital Trim
EBT - Earnings Before Taxes
EFI – Electronic Fuel Injection
Expo – Short for expotential, in Radio Control it is the ratio of the transmitter stick movement to the servo movement. Typically more stick movement, for small servo movement thus finer control
f - Frequency
F2F – Face To Face
FFF – Fan Fold Foam
FG – Fiberglass
FNV – Front Needle Valve
Freq - Frequency
Fuse – Fuselage
g - grams
GB – Gear Box
HD – High Density
HOR – Hell On Rails
HS – High Speed
Hz – see hertz
IMO – In My Opinion
JR – Japan Radio
Kg - Kilograms
LSI – Large Scale Integration
Kit Built – To build a model from a kit see also Scratch Built, Plan Built, ARF, ARTF and RTF
Lbs. – Pounds
LE – Leading Edge
LG – Landing Gear
LS – Low speed
Ltr – Liter
Max – Maximum
MECOA - The Model Engine Company of America
MG – Metal Gear
Min – Minimum
mm – millimeter
MT – Monster Truck
mv – millivolt
NIB – New In Box
NP – Neutral Point
NR – Never Run
Oz – Ounces
Peak Detect – Usually refers to charging batteries, a method to check peak voltage when charging batteries
Plan Built – A model built from printed plans, parts are cut, assembled, and exterior is finished by modeler - see also Scratch Built, Kit Built, Plan Built, ARF, ATRF and RTF
Poly Urethane Glue – An expandable glue that requires water to set, Examples: Gorilla Glue or Elmer’s Pro Bond
POST – Power On Start-up Test
Prop – Propeller
PUA – Poly Urethane Adhesive – examples: Gorilla Glue or Elmer’s Pro Bond
RIP – Rest In Peace
RNV – Rear Needle Valve
RO - radio operator
Rx – Receiver
RTF – Ready To Fly a model that comes fully assembled with radio - see also Scratch Built, Kit Built, Plan Built, ARF, ATRF and RTF
SAM – The Society of Antique Modelers -http://www.antiquemodeler.org/index2.html
SC – Single Conversion when referring to radio receiver, or Supercharger
Scratch Built – A model designed, cut out, built and covered by a person - see also Kit Built, Plan Built, ARF, ATRF and RTF
Sec – Seconds
SMT – Surface Mount Technology
S-PPM – A JR receiver fail safe mode that will cause the servos to β€œhold” then go to a programmed preset position after a predetermined period of time of lost or scrambled signal
STD – Standard
Super Charger – A power assisted device that compresses air into an engine
TD – Tail Dragger
TE – Trailing Edge
TF – Top Flite
Thermal Detect – The detection of heat of an object
Turbo – Turbo Charger, a device to compress air into an engine that is not power assisted (see super charger)
Tx – Transmitter
TY – Thank You
VIP – Very Important Person, In SCUBA compressed air tanks (for starting Jets) it means Visual Inspection Process and must be done once a year
vs – versus
VTR – Variable Trace Rate, allows different servo speeds for each half of transmitter stick, similar to expo
VVVF - Variable Voltage Variable Frequency
W/ - With
W/O – Without
WJM – World Jet Master (Team)
WM – World Models
WTB – Where To Buy or Want To Buy
WW1 – World War One
WW2 or WW II– World War Two
X-wind – Cross wind
YCD – You Can Do
YHM – You Have Mail
Z-PPM – A JR receiver fail safe mode that will cause selected servos to β€œhold”, and other selected servos to go to a programmed preset position after a lost or scrambled signal after a predetermined period of time
To get to the end of this, or any other RCU post, just push the blue right arrow, shown at the end of the subject line.
To cut and paste the list into your favorite word processor, first highlite the list with your mouse, then push "CTRL-C", open your word processor and push "CTRL-V".
The above is to the best of my knowledge, and should be considered a starting point. Please let me know any changes you would like to see - any, and all, suggestions are welcome.
Wayne Miller
Old 11-11-2004, 06:40 PM
  #123
Hi,
New list as of Nov.11,2004, see below.
Wayne
A – In electrical formulae this is short for Amp, a measurement of current. It takes 1000 milliamps to make one amp. The symbol for amp in electrical formulae is β€œI”. Example: I=E/R (that is: Amps = Volts divided by Resistance in Ohms). Also see other symbols E,R, and P.
Airfoil – The curvature on a flying surface (wing, propeller etc.) that creates a lift or pull.
Angle of Attack – The difference between a surface going flat into the wind, and going into the wind at an angle.
Angle of Incidence – See incidence
APG – Aileron Positioning Guide
ARO – After Run Oil
Attachment – A file attached to an email
AKA – Also Known As
BB – Ball Bearing
BC or B/C – In emails, short for β€œbecause”
bcnu – In emails short for β€œBe Seein’ You”
BF – Short for β€œbefore” or Bayerische Flugzeugwerke Bavarian Aircraft Works - Willy Messerschmitt's company and makers of the Messerschmit ME109
bfn – Short for β€œbye for now”
Browser – Software used to access the internet
BTW – By the Way
C(number) - Capacity times the number. Example C10 is ten times the capacity of a battery in ma. C10 for a 3000 ma (3.0 amp) battery pack would be 30,000 ma, or 30.0 amps.
C/(number) -Capacity divided by number. Usually used to describe battery charge rates. Example C/10 is the battery capacity in ma divided by 10. In the case of a 3000 ma (3.0 amp) pack this would be 300 ma
C/W – Short for β€œcomplete with”
CF - Carbon Fiber
CL – Control Line
Clevis – A clip on connector between a control (push) rod and servo, control horn or throttle.
cm – Short for centimeter. In emails its short for β€œcall me”
Cockpit – The area a pilot sits to control an aircraft.
COL – Cry Out Loud
Control Surface – A surface that controls wind deflection for controlling movement, such as, aileron, elevator, rudder flaps etc.
Crank – Short for the β€œcrank shaft” of an engine.
CW – Clock Wise
cw2cu – Short for β€œcan’t wait to see you”
Dive Brake – Surfaces on a wing to create a drag to slow airspeed when deployed.
DT – Digital Trim
E – Electrical symbol for voltage. Example formula: E=IR (that is: Volts = Amps divided by Resistance in Ohms). Also see other symbols I,R,A, and P.
f - Frequency
F2F – Face To Face
FCOL – For Crying Out Loud
FFF – Fan Fold Foam
FG – Fiberglass
Flaperons – Ailerons that can be used both as ailerons and/or flaps
Flight Simulator – In radio control, a program used on a personal computer to simulate flying a model aircraft with joysticks or a radio control transmitter.
Freq - Frequency
Fuse – Fuselage
Fuselage – The main body of an aircraft
g - grams
g2g – Short for β€œgot to go”
GB – Gear Box
Glow Plug – A screw in plug, usually at the top of a glow engine, with a platinum coil that requires heat to ignite alcohol to start the combustion process, once started, the heat from subsequent combustion keeps the coil hot and the engine working.
Glow Engine – An engine that relies a glow element to operate.
Gopher – short for β€œgo for”, or a menu driven system to get information
GPS – Global Positioning System, an electronic system to find a location or position
gr8 – Short for GREAT
gyab – Give Yourself A Break
HD – High Density
HOR – Hell On Rails
Hover – To suspended an object in one place using an internal or external power source.
HS – High Speed or Hobby Shop
Hz – see hertz
IMO – In My Opinion
Incidence – The difference in between a surface (wing) being parallel to the center line of the aircraft and a wing offset from the center line. If the front of the wing is up, its positive, if down its negative.
JR – Japan Radio
JSF – Joint Strike Fighter (F35)
Knife Edge – To fly a model β€œon its side”, the wings are vertical to the ground instead of horizontal
Kg – Kilograms
Kv – Kilovolt or 1,000 volts. With electric aircraft motor specifications Kv means 1,000 RPM (revolutions per minute) per volt
Lbs. – Pounds
LE – Leading Edge
LG – Landing Gear
Low Wing – An aircraft with the wing on the lower part of the fuselage.
Loop – An inside loop is a maneuver where an aircraft goes into a vertical circle using up elevator (an outside loop uses down elevator).
LS – Low speed
Ltr – Liter
Max – Maximum
mbrsd – Short for β€œembarrassed”
MG – Metal Gear
Min – Minimum
mm – millimeter
MT – Monster Truck
mv – millivolt
Mosaic – an older web browser
NIB – New In Box
NiCd – Used to describe a type of battery - Nickel Cadium
NiMh – Used to describe a type of battery - Nickel Metal Hydride
Netscape – A web browser
NP – Neutral Point
NR – Never Run
Ornithopter – An aircraft that flies by flapping its wings.
Oz – Ounces
P – In electrical formulae it is short for Power in watts. Example formula: P=EI (Power = Voltage divided by amps. See other symbols E,I,A and R.
Piston – A mechanical device that moves in a cylinder to deliver/receive pressure, transfer combustible energy, or move liquid or air.
PoP – Point of Presence, the access point of a system to the net
Prop – Propeller
Propeller – Usually located at the front of an aircraft or at the back of a boat in the water, it spins to move air or water to propel the aircraft or boat
Prop Wash – The wind, or water movement created by a propeller when it is turning
Pusher – In model aircraft, a craft that has a propeller located someplace behind the wing, or at the back of the aircraft to β€œpush” air instead of having a propeller at the front pulling air to create forward motion.
R – In electrical formulae, resistance in ohms. Example formula: R=E/I (Resistance in Ohms = Voltage divided by Amps). See other symbols A,E,I, and P.
Radial Engine – An engine with three or more cylinders, usually evenly spaced, going around the engine
Resistance – Designated as R and one unit is  (ohm). Is a value of how much an electrical device limits the electric current: One volt applied to a resistance of one ohm has a current of one ampere. Also see symbols R,A,I,E and P.
RH – Right hand side (in reference to airplanes – right hand side of pilot when facing forward in cockpit)
RIP – Rest In Peace
RO - radio operator
Roll – An aircraft maneuver where the aircraft rotates around the fuselage, usually using ailerons, while moving forward
Rx – Receiver
Sec – Seconds
Snail Mail – Mail sent through the postal service
Spam– Unsolicited email, usually advertisements
Spamming – The sending of Spam
STD – Standard
sup – Short for β€œwhat’s up?”
TD – Tail Dragger
TE – Trailing Edge
TF – Top Flite
Tx – Transmitter
TY – Thank You
uuencode – An older method of converting (encoding/decoding) binary files to text based characters
vs – versus
W/ - With
W/O – Without
WAAS – Wide Area Augmentation System a GPS (see GPS) system to accurately find location
WM – World Models
Winsock – Short for Windows Socket, a file usually used to connect Windows and the net
wtd – Short for β€œwanted”
WW1 – World War One
X-wind – Cross wind
YCD – You Can Do
YHM – You Have Mail
Wayne Miller
Old 11-11-2004, 08:18 PM
  #124
May as well chime in:
Gas - usually means gasoline AOT (as opposed to) glow fuel, but can mean any internal combustion engine AOT electric.
Old 11-15-2004, 03:54 PM
  #125
Hi rcjon,
Consider them added. They will be in the next list that I will publish in a week or two. Thanks for your help.
Fly4Fun,
Wayne
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
