Canopy Curled after painting
I painted a Top Flite P51 canopy after I cut it to fit the plane with Lustercoat primer & lustercoat paint, after I painted the canopy, the edges of the canopy curled out. How do I prevent this from happening again? Thank you Allen Josephsen [email protected]
IL
RE: Canopy Curled after painting
If you use very light coats you can probably get away with LustreKote but the thinners in LustreKote aren't really compatible with Lexan. Best to use the paint that is specifically for Lexan (polycarbonate).
My Feedback: (26)
Top Flite claims that to get good results using Lustre Kote on a canopy to spray the paint into a cup and let a lot of the thinner evaporate. It can then be painted on with a brush. The thinner in the paint is the culprit, softens the plastic. I belive you can use Perfect Paint right from the can with no adverse affects, and it is available in most all of the colors to match MonoKote.
Pilgrim
Pilgrim
