LEFT OR RIGHT THRUST??
RE: LEFT OR RIGHT THRUST??
Depends on the plane. Some do some do not. Look on the plans and in the instructions. If it calls for some then use it. If nothing is said then I would set it up dead straight. You can always shim later if need be.
Mark Shuman
Mark Shuman
TX
ALWAYS RIGHT HAND THRUST AND A LITTLE DOWN THRUST WON'T HURT.ABOUT 2 DEGREES RIGHT AND 1 DEGREE OF DOWN IS A GOOD RULE OF THUMB.THIS IS TRUE OF GLOW POWERED PLANES ALSO WHEN TAIL DRAGGER GEAR IS ON IT
