Reload this Page >
Cleaning questions
Cleaning questions
Old 05-25-2004, 07:48 AM
REVgst
REVgst's Avatar
Default Cleaning questions
Hey guys, I was just wondering, what do you all use to clean that pesky glow fuel off of your planes. I know it is impossible to remove it all. As far as I know, any substance that could remove it all, could also damage the covering and plastic parts(ie paint thinner) I have tried using house-hold cleaners like fantastic and have also tried things like 99% alcohol prep-sol, but to no avail, any suggestions?
Thanks.
Old 05-25-2004, 10:25 AM
MinnFlyer
MinnFlyer's Avatar
Default RE: Cleaning questions
geeze, how clean are you trying to get it???
Most of use agree that household cleaners (Especially window cleaner with ammonia) works fine.
Old 05-25-2004, 10:31 AM
bigchap
you are not the first to ask the answer to this predicament,the answer is simple-anything with orange oil in it and a cloth.
Old 05-25-2004, 10:34 AM
Deadeye
Deadeye's Avatar
Starting fluid (ether) will remove ALL of it. It doesn't damage monokote, econokote, ultrakote, oracover, or coroplast. I can't vouch for any other covering. Just wet the rag and wipe, turning the cloth for a clean surface once in a while.
Old 05-25-2004, 10:50 AM
TNRabbit
TNRabbit's Avatar
Ammonia will break down monokote and the ahesive used on the backing; if you use a household cleaner, use one without ammonia. I've found that "Simple Green" mixed with water @ 10 to 1 and a little alcohol added to it works fantastic.
Old 05-25-2004, 11:28 AM
REVgst
REVgst's Avatar
Ahh, thanks for the information. I will try all of those to see what ones work the best. And to answer the question about how clean I want it, I just want to get it clean enough so when I pick up the plane after cleaning it, my hand doesn't look like I just preformed an oil change,lol.
Thanks again for the info.
Old 05-25-2004, 12:38 PM
MinnFlyer
MinnFlyer's Avatar
Switch to 4-Strokes
Old 05-25-2004, 03:10 PM
AIRPLANENUTS
I use rubbing alchohol with a little Dawn mixed in. Works great!
Old 05-25-2004, 06:10 PM
REVgst
REVgst's Avatar
LOL, MinnFlyer...I DID do just that! Now I have 2 4-strokes, and only 1 2-stroke.
A RCV .91 CD
A OS FS 91
and an Enya SS .50
-I like the 4-stokes wayyy more.
Old 05-25-2004, 06:29 PM
TNRabbit
TNRabbit's Avatar
...I've also found that brake cleaner takes off everything....including the covering!
Old 05-25-2004, 07:57 PM
scubyfan
I use diluted rubbing alcohol. Do not use 90% or 75%: mix it with water until the mixture is 50% alcohol w/ water. Get one of those spray bottles. Spray on the mix, rub it off with a paper towel. Nothing comes close, and will NOT damage any part of your plane.
Old 05-25-2004, 09:55 PM
voyager_663rd
summer windshield washer fluid out of a plant mister spray bottle/paper towels.
Old 05-26-2004, 04:31 PM
REVgst
REVgst's Avatar
Thanks for all of the input guys.
Now I will be able to keep the fleet nice and clean!
Old 05-28-2004, 07:15 AM
prebres
My Feedback: (7)
prebres's Avatar
Baby wipes with lanolin work great, and leave you plane smelling fresh!
Old 05-28-2004, 05:16 PM
REVgst
REVgst's Avatar
MMMM, spring-time fresh airplane,lol.
