Reload this Page >
What kind of biplane is this???
Old 05-29-2004, 11:23 AM
ep3j
My Feedback: (9)
Default What kind of biplane is this???
I was prone to think Skybolt... However that seems not to be the case. I would like to know for the purpose of a cowl and CG. Also anything else that could be of use.
ID:	137541   Click image for larger version
ID:	137542   Click image for larger version
ID:	137543   Click image for larger version
Old 05-29-2004, 11:55 AM
Patriot
Patriot's Avatar
Default RE: What kind of biplane is this???
Looks like a bashed Balsa USA Phaeton 90, with the lower wing swept back, modified tail surfaces, and a canopy instead of open cockpit.
The fuse shape, strut-work, landing gear, wheel pants, and the lower wing ailerons all look the same as the Phaeton 90.
Patriot
Old 05-29-2004, 12:05 PM
Live Wire
Live Wire's Avatar
Andrews AeroMaster ll you could make 3 versions from one kit . This one was the most popular 4'' larger wing span and both wing swept back. If I am not mistaken it has a 52'' wing span.
Old 05-29-2004, 12:25 PM
Patriot
Patriot's Avatar
Ah Yes, the Aeromaster!!!
Never even thought of that, but sure looks like it.
Patriot
Old 05-29-2004, 12:34 PM
Live Wire
Live Wire's Avatar
With out the extension on the fire wall for 2st engine you could mistake it for a Jug!
Old 05-29-2004, 05:16 PM
Live Wire
Live Wire's Avatar
eP3j Got you PM and thought it might help some others to.
The Aeromaster was Distributed by Great plane for a while and they are the ones that discontinued it. and yes the super had a built up cowl made it look like a Waco YMF or UPF they also used the cowl ont the larger model. The original kits had the cheeks on each side of the motor and bottom. There are a few of these kit in circulation yet but they are getting scarce . For more information you can do a search and find a lot of information.
