OS 91 DF low end help
CO
i need help with my OS 91 DF engine. i don't know where the low end screw mixture needs to be. is there any who who know how many turns out it needs to be. I'm not really sure what the problem is but every time i start the engine i have to have it at half way open to keep it running and then if i give it full throttle the motor starts dieing. so i could really use some help.
thanks
Chase
thanks
Chase
MD
RE: OS 91 DF low end help
Dubb Jett has an excellent tutorial for adjusting both high and low mixtures on his web site:
www.jettengineering.com
follow the link to "tech specs and instructions"
MA
91 fx 2 1/2 turns out from bottom . after you have made your adjustments, start the engine and set the needle valve first high end then fine tune the lower
