Adding oil to fuel
My Feedback: (7)
Adding oil to fuel
I'm going to be getting a YS 53. I'm going to be using Cool power synthetic fuel in it. The ? is YS recommends 20% oil for the YS, can I add Castor oil to bring it up to 20%, or should I avoid castor for this engine. I don't have access to YS 20/20 or power master 20/20. What synthetic oil could I mix with the Omega Cool Power? Thanks to all for any input!
FL
Adding oil to fuel
rcdemon,
Unless the manufacturer recommends synthetic oil only I would add castor. Castor has better rust protection and is a better lube if the engine goes lean. I always use fuel with at least some castor, the only problem I have with castor is that it causes varnish and can get unsightly on the mufller and head.
My Feedback: (7)
Adding oil to fuel
I know that castor is a plus for most engines and I add it regularly to my fuel to bring the oil content up tp 20%. I've heard that to much castor can cause problems with the regulator on YS engines, they have a internal pump.. What I need to know is if 3% castor in my fuel will cause problems with the pump, or if I can add Koltz synthetic to the Omega Cool power and have it mix with the synthetic oil in the cool power????
FL
Adding oil to fuel
Again unless YS recommends synthetic oil only I would just use castor but if your question is will Koltz mix with the synthetic in Cool Power the answer is it will. I can't imagine that 3% castor would hurt a thing but after you get the engine the instructions should tell if you need all synthetic oil or if a blend is "OK".
SC
Adding oil to fuel
The YS manual indicates you can use castor, but most people use all synthetic to prevent gumming up the valves and valve seats. I normally run Cool Power Pro Pattern 20/20, but in a pinch I've run Cool Power 15% with an extra 4 ounces of Klotz with good success.
