Servo Reversing by rewire?
My Feedback: (7)
NJ
Help,
Does anybody know for certain if you can reverse a servo by changing the position of the wires ( red, black, and white ) in the connector. I know you can reverse the servo's action by flipping the dip switch in the transmitter. Let me explain why I am asking this question.
I have just built two planes. One for me and one for my son. Due to financial considerations we were planning on using the same transmitter. A Futaba 6YG-FM. Much to my dismay I have found that my channel one and his channel one ( aileron) servo must operate in opposite directions. In theory we could flip the dip switch in the transmitter to the correct position each time for whichever plane is going up but this is dangerous. If we get it wrong one time something bad will happen. I would like to 'wire' my servos to act correctly for the current transmitter settings. Any help or ideas are greatly appreciated.
RE: Servo Reversing by rewire?
In Short NO- This does not work...
If you must use the same transmitter write down the setting for each aircraft on a piece of paper including the dip switch positions, and make this part of your preflight. If this is your standard it will be like second nature-
Better yet find a used transmitter on e*ay or at your LHS. You can get them surprisingly cheap- 20$ = 4ch etc....
To reverse the servos you need to use a servo reverser (see link) You need to reverse the signal that is transmitted to the servo via the (white wire)
http://www.ripmax.com/ProductFrames/P-RME2050.html
If you MUST use a single Tx- I still recomend that you write down the trim settings for each model.
Like they all say you can not reverse the servo by rewiring the connector. They can however be reversed if you are handy with a solder iron. Open up the servo and you will see 3 wires going to the motor and another 3 going to the pot. Swap over the two outer wires (usually black and red) on both the pot and motor.
My Feedback: (8)
It seems to me that everyone is missing the simple solution!
Just put whatever connector you are using at the servo on the other side of the servo horn. Actuation now works in reverse.
Another relatively inexpensive solution is to get a reversing "Y" connector and connect the servo to the end of the "Y" that makes the servo go in the direction needed.
Bad info Flyboy, I'm from the old days too if the 50's and 60's are old days, and NEVER saw a feedback servo that could be reversed by simply reversing the positive and negative leads. Even back then you had to reverse both the motor leads and the outer leads to the potentiometer.
ND
My servo went Kapoof,dont you remember?.......lol I didnt bother to read all the post But I had the same problem and tried rewiring the servo then as I turned it on I had a small but realistic camp fire in my wing...lol Some chap in RCU then told me about a specific servo reversing wire and its a Y wire for when you want one to be opisite of the other but work in the same direction. He gave me the tower part # hopefully some one had it for you. This place is out of this Wor....ld PS reversing can be done internaly but it has to be done in two places and if you ask me buying the wire is easier its around 18 bucks
ORIGINAL: airroy
Help,
Help,
The easiest way is to move the servo arm to the opposite side of the servo.
your radio doesnt have a reversing function or different model memories?
if not. you may have to remove the servo and turn it to face the same way to mach the outher model yo can do this but you may have to make new mounting set up. or if you must change the wiring the way I see it is leave the black in place thats the neg side
switch the red with green or yellow depending on the colors you have ,switch the incomming wires and then switch the wires to the pot the same way but leave black alone. Now this was my idea to do the last time,But I thought of it too late I just tried to switch the incomming wire,nothing happened but when I messed with switching the black and red it blew up the servo,so like I said leave the black in place and switch the color wires in two places ,incomming and the pot off the board
ORIGINAL: Rodney
Your right, forgot about that. Like I said, it had been years since I did it. Forgot about the motor. Still don't advise it. Transmitters are cheap if reversing the switch is a big deal.
In the great planes ryan STA you have to reverse a servo. Info is in the downloadable manual. There is a servo reverse adapter made. The manufacturer and model # is mentioned in the manual.
Donnie
Donnie
IL
If you want to go with a servo reversing harness, here's the link to what you need from Tower. $18.99 This one is for Futaba, there's also one for JR.
http://www2.towerhobbies.com/cgi-bin...&I=LXAFN1&P=ML
You may also want to think about a 6-channel (or more) computer radio. It makes setting up all the servos much easier and will have the ability to hold the programs in it's memory for multiple planes. Pre-flight checks on all the control surfaces is still a good idea though no matter what radio you are using. Get into the habit of doing that before each and every flight and you'll never lose a plane due to a surface moving in the wrong direction.
