CG for Super Stik
UT
CG for Super Stik
Could anyone help me with the location of the cg for a hanger 9 SUPER STICK.
How far back from the leading edge of the wing is the cg?
Also how far back from the leading edge is the cg for a GOLDBERT TIGER 60?
Thank you for any info you might have.
Al Williams
Al Williams
BC, CANADA
RE: CG for Super Stik
Hello; I just finished building the Super Stick and the CG is supposed to be 1/8 inch behind the front spar, but I had to add 6 oz. and a Harry Higly Heavy Hub to my OS .46 LA and it was still tail heavy. After doing the math I realized that 1/8 in. behind the front spar is less than 25% of the wing chord. Mine balanced out at about 1/4 inch behind the spar which is about 26% of the wing chord. I took it out this weekend and it flew fine. Hope this helps. Cal.
