epoxy???
AK
Don't do it!
Keep the mixture the same! (or it may not cure at all)
If you want to extend the pot life, use temperature. Keep the epoxy cool before mixing it, and it will have a longer pot life. Or, use a more shallow cup. Epoxy wil kick faster when you have a lot of it in a tall slim cup.
Better yet, simply buy epoxy designed to have a longer working time, such as West Systems epoxy. There's a lot of free and downloadable info you can take a look at, at http://www.fibreglast.com
epoxy???
The answer to your question is NO!.
For epoxy to cure properly the hardener/resin mix has to be fairly accurate. I weigh mine on a gram scale. Certain makers of epoxy resin supply different types of hardener. Fast and slow for example. Fast will usualy give about 30 mins pot life while slow (Depending on the Manufacturer) will give a couple of hours. These hardeners can also be mixed to give a pot life of your choice.
Ed S
Ed S
My Feedback: (16)
GA
epoxy???
I don't know how much longer you are talking about but you can mix a little denatured alcohol to the 50/50 mix to thin it and increase the working life.
As the above post states, just purchase the correct epoxy is the best solution
epoxy???
Thanks guys!
Yes, using a slow curing epoxy system is definitely better. I took over someones project, and unfortunately, I have large amount of 2020 hardener (from Fibreglast) - which I have to get rid of. Just trying to find a way of extending the pot life so that I can use it for something useful like glassing foam wings.
Mike
Mike
epoxy???
If you mix alcohol or acetone with the resin to thin it slightly the integrity of the mix will be affected. It might not cure properly, it could stay kind of rubbery. Literature from West Systems discourages this practice.
Ed S
Ed S
